going to buy a narrow crown finish stapler. either bostitch or senco. can you use senco 1/4 inch staples in a bostitch stapler? are these actually the same.. they both seem to measure out to 7/32 ?
I have had very good results from my Porter-Cable, it's worth a look.
P-C. Inexpensive, reliable. Good Luck!
John
would concur, never a problem with my pc air tools. cheap too.
good luck rg
Might as well take my vote for the Porter Cable too - great tool!
geez, lemme throw in a plug for the senco. I've gone years without hearing one good thing about PC air tools, now three ayes in a day. Whazzupwiththat? Oh well. My narrow crown is a bostitch, and it works fine, but most of my other guns are Senco, and I guess at this point I don't intend to ever buy anything else. Reliability is a good thing.
"The child is grown / The dream is gone / And I have become / Comfortably numb " lyrics by Roger Waters
which model of bostitch narrow crown stapler do you have ? do you use bostitch or senco staples? no jamming, or other problems. bostitch comes in 1 3/16 and 1 3/8 staples. senco comes in 1 1/4. does bostitch have enough power to nail hardwoods?
I don't know the model # either, but it was only about $100 if that helps. It's got enough oomph for anything I've tried it on.
Another post - staples for crown? Gack. Please don't be rude to your trimwork!"The child is grown / The dream is gone / And I have become / Comfortably numb " lyrics by Roger Waters
I have the Bostitch narrow crown stapler. I also have a framer, a 15g finisher, and a roofer.
Best I can tell, it makes absolutely no difference what brand of fasteners you buy -- if they are narrow crowns, they'll work in my bostitch. If they're 15g angled-stick finish nails, they'll work in my finisher. And so on with the others.
So far (about 4 months now) the Bostitch has been good to me. Note that I have no experience with others.
which model bostitch narrow crown stapler do you have? do you use only bostitch 7/32 staples or do you use senco 1/4 inch staples. is senco all that, or does bostitch have lots of power also. ive been looking at senco sls-20 and bostitch sx150 k-1
I don't recall which model number of Bostitch I have -- it's the one that is a narrow crown stapler only. It won't shoot brads. Lowes has them, usually for around $79.
The Bostitch has enough power to get the job done -- don't know if that is "lots of power" or not.
I got the Bostitch because for me, it was easily available, and the price was good. If my budget had allowed a thorough search for the absolute best, I would probably be using Senco for all of my nailers. Senco is probably the most respected name in the power fastener market -- their guns a powerful, durable, well balanced, high-quality pieces. And the prices reflect it.
Vast projects should not be founded on half vast ideas.
Slightly off topic, but what is the value of a crown stapler vs a nailer for putting up crown molding?
I would not use a stapler for hanging crown. (They are called narrow crown staplers because they shoot staples that have a norrow crown -- as opposed to the "normal" staples that fit your Arrow T-50. The name has nothing to do with the purpose.)
For crown molding. I use my finish nailer, usually with 2 1/2 inch nails. That's enough length to get to the studs and joists -- something that staples won't do.Vast projects should not be founded on half vast ideas.
Thanks for the explanation. I guess it shows how little I've done here. I just assumed that the 'crown staples' meant for crown molding. I did see references to using two nails to kind of 'pinch' the crown molding to the backing and thought that the staples might be able to do this same thing in one application.
I'll use may nailer. Thanks again.
I use staples for painted trim, including crown, all the time. Great holding power and no more to putty than nail holes, just make sure you align with the grain.
If your stapler is capable, and if you are using 1 1/2 inch staples for crown, then that might be OK.
If you are using staples that aare 1 1/4 (or less), then you aren't getting enough "purchase" in the framing (my opinion anyway). Assuming that the crown is 1/4 thick where the nails goes through, and the drywall is 1/2, then you need at least another 3/4 to go into the framing. (Normally I like to have two thirds of the nail in the framing, the rest in that being held or "gone through ".)
I prefer to use 2 1/2 inch nails, so there is not any question. In some cases, I can even shoot a nail through the center of the crown as a temporary hold, then more through the edges into the framing.Vast projects should not be founded on half vast ideas.
Another vote for the PC, wish I had one long ago, I find it much more useful than my brad nailer (also PC).
PMB
http://benchmark.20m.com
