My Bandsaw that sits often in a corner
My Bandsaw that sits often in a corner and not used…
Not any more.. OHhhh.. Are hard are we to break old habits!
I ALWAYS rip my stock on my table saw.. BIG mistake.
I have this so called junker bandsaw. A Rikon 18 inch. I’ll leave it at that…
My shop is very small so my TS was stuffed someplace out of the way so I could get my bandsaw out in the light of the garage doors! I wanted to resaw a few sticks of my Panga-Panga to use as thin strips about 1/4 inch thick and 5 inches wide.. I ‘think’ may be part of the laminated pencil post legs. I have to make eight of them.
Making two canopy beds for my little China dolls.
Anyway, It all started out to rip some stock for a neighbor. Maple, which I never use. Nothing wrong with the wood. I hardly ever use it these days.
I started to cut a 4X4 by 9 foot long maple ‘stick’ and I saw sparks someplace. I turned off the saw and after several minutes the blade came to a stop! Dang those cast iron wheels want to keep on spinning!
Gee,, After a bit of ‘cussing’ and ‘fussing’ I found a frozed? ball bearing that guides the blade! DANG! No way to fix it..
Anyway I made a wooden spacer to replace the BAD BAD bearing…But I thought my one inch blade I always use would not like it.. Lower support bearings which I think are more important than the upper? Or do I have that backwards?
I have only used a 1 inch wide 3 tooth per inch blade for all my cutting…
BIG mistake thinking back. Not knocking that blade!
EDIT:
I hit the wrong somethng and this got posted before I was finished!
I changed over to a 1/2 inch wide blade four teeth per inch. A Lenox tri? metal..
4 tooth per inch I measured… ALL 0.250 apart!
I WILL never RIP A long STICK ON THE TS AGAIN..
As a test I marked the edge of the stick I was ripping,, My junk saw with a 1/2 inch try-metal blade will cut anything.. Wood that is… Accurate center on a 9 foot long board,, Yes I used feather boards. My TS was better at it but not by that much! I felt MUCH safer on the bandsaw..
Edited 10/5/2008 10:11 pm by WillGeorge
Not sure where your going with this. Did you get your strips cut?
The wooden guide replacement should be fine, after all it is only a guide for the blade. If you have your blade is tracking properly, the wood surfaces against the table and fence are square you should have no trouble. The wooeden guide will heat up from excess friction if your tracking is off.
The seized bearing should be easy to replace.
Don
