Seems to be somewhat of a kerrflooey on the G&G Yahoo site about the secret stain formulas that the Hall/ Greene brothers may have used and are now being marketed by a former craftsman who did restoration/preservation at some of the most famous houses.
see
http://www.rmdesignconst.com/Products.html
What if anything has anyone experienced with this stuff?
Also of note is the extremely thin shellac cut used as a sealer over the stain before the BLO was applied :
“shellac with
white shellac one part, alcohol seven parts;”
Inputs anyone?
Boiler
I have not visited the G&G site but just finishing Darrell Pearts G&G book it does mention the finish.
Chemical treatment: Bichromate of Potash, saturated solution.One part to four parts water. Brush on and wipe off as work proceeds. One coat.
Filler/Stain:
Chrome yellow L.3-1/2 parts
Sylvan Green 1/8 part
Raw Umber 3 parts
White Lead 2-5/8 parts
Use 19 parts of raw oil with dryer. Wipe off.
After 48 hours rub in oil, wipe off thoroughly. and polish with cheese cloth. After 48 hours repeat the last.
No mention of shellac. The oil is lineseed oil. I wonder what dryer he was refering to?
Shoe
Shoe,Yes, I was aware of that finish.
It is the Berkeley document and that has become suspect and it relates directly to the Thorsen house which overall presents a red bias finish vs. the yellow bias found in the Gamble work. Of course this could all be a matter of wood lots and the finisher's "Hand". Darrell Peart hangs out a lot on the G&G site and it seemed that he was also wondering about it. Jim Ipekjian, arguably the foremost authority on G & G weighed in with: "I have run across countless claims of "magic" or "secret" finishing formulas. We
all have, as the result of varying materials, climate, and availability, had to
develop solutions that fit a particular situation. I would suggest there is no
magic and there should be no secrets."The fellow that produce these stains worked extensively on the Gamble house and indicated that he was introduced to one of the original finishers there. If he hadn't given him the "secret" he would have taken it to his grave. This was in early 80s. This was all pre-Darrell Peart era. I have noticed Peart's work seems to fall in the true brown to reddish range and perhaps this is the result of the Sylvan green formula.
The dryer was probably a variation on Japan Dryer. Since these days BLO is most commonly used a dryer would be unnecessary.
As to the text, it is from a Huntington Library Art collection archive note on finishing the Robinson house. It reads: "CHEMICAL STAIN: Two coats chemical stain, sanded with
#00 sand paper after each coat; allow 48 hours then.shellac with
white shellac one part, alcohol seven parts;- Sand with #0000
sand paper; Apply boiled linseed oil and rub to dull polish with
cheese cloth. Surfaces must be rubbed with cloths until no oil is
left on, them. Living Room and stairs, West Sun Room, Dining Room,
Passages, Nook Den and all Bed Rooms and Closets except No.4. to
be finished in stain. Make sample for Arohiteot. The Bed Rooms
and Closets and Passages to be light brownish color and the other
a dark brown. Walls of Bed Rooms to be papered, and their oeilings
sized and tinted. Walls of Bed Room closets up to hook strips painted
with two coats Flattone, tinted above. Walls of Living Room,
stair well up to second story, west Sun Room and Dining Room painted
three coats Flattone. Last coat glazed on.Ceilings painted two ooats Flattone. Sizsd ( S-W Mixing eize)
first if necessary. Ineides of china closet and bookcase. stained
and finished. Wood knobs and handles to be two toned. East Sun
Room ceiling painted two coats Flattone. Wood work oil stained
and shellaced."and a variation ; see attached photosJust wonderingBB
Edit: the "fellow" that had the secret that was passed on was in fact Donald Hall, son of Peter
The whole transaction between the current manufacturer and Donald Hall is unwitnessed.
Edited 10/17/2009 6:18 pm by boilerbay
Those are neat little snipits of history.
The white lead? does this mean there is lead in the original furniture/houses? did the finishers suffer lead poisioning?
I worked with on old printer, he said they were given a pint of milk a day to reduce their lead content. This was in the days of hand set type and cast lead printing plates.
Cabot's Creasote? A tad toxic sounding?
"White lead?"My first thought was as a filler but more probably as a pigment extender for the other stuff and to control the hues, other than that I don't have the foggiest.BB
The lead oxide would have also provided some flexibilty to any film and acted as a dryer.
The lead would have to be ingested for major problems--the printer's problems comes from the vapors from molten lead which is inhaled. Benjamin Franklin was aware of the dangers of lead poison for printers casting type.
Since just about all paint had lead until the 1970's it's poisoning likely wasn't acute. The big problem today is old lead paint chips that tend to be sweetish tasting, and ingested by toddlers.
Steve,"The lead oxide would have also provided some flexibilty to any film and acted as a dryer"Didn't think of that. Good thought.BB
How to Verify That UGG Boots Are the Genuine Short article
Today's Sandal General trends From around the globe
Would you like to bare an individual come july 1st? Footwear improve the the summer time wardrobe and let you have enjoyment and then funky with the laid back garment. This year's designer fashion runways contain a bumper pick of new shoe trends from around the globe. Provided by thigh-high gladiator sandals resorts in jamaica in order to throwaway jello flip flops, you'll find very nearly any seem you want in this summers the latest shoe fads.
Benefit from it you will get whenever you cross-stitching this gladiator sandal by using UGG boots? You might have primary amazing contemporary suede bootie shoe. In the lower back, bootie shoe appearance being a cheap case suede trunk, loosely and comfortable. The front side within the shoe top will be remove into a thong model shoe with a bootie lower-leg. It's really a glance this contradicts information normally has no repair their fortunes audio everywhere near as hot simply because it appearance. Which may be one amongst the modern trendy designs intended for sandals resorts this summer. Consider a lot of these other people, through laid-back to help classy.
Any Typical Reverse Lemon
Will there be every footwear that says summer months a great deal more definitely compared to the traditional summer season utilize flop? Sandals resorts in jamaica came further through the cloth or sponge rubber cutouts of one's 1960s, however. This year's change failures types can be bought in a lot of top items, however the keynote of fashion the year of 2010 is usually colour. This season's colours seem to be eye-popping, brilliant together with active. Designed for everyday bch dress in, flip-flops having impish behaviours imprinted relating to the soles along with walkfit shoe inserts are especially the fad, in particular when a thong-strap sporting activities a good style from the printing. Check out vast daisies inside wacky colorations concerning sandals along with daisy-printed bottoms, put on with the help of short, tankinis and even sundresses. You can aquire at bay by way of flip flops with respect to evening wear whenever you opt for see-thorugh jellies along with glimmering rhinestones which often apparently float previously feet, and / or conjure up a casual down-to-earth check with the help of braided leather material flip-flops.
Thong Footwear
T-strap thong sandals resorts in jamaica happen to be evergreen the hot months favorites. The 2011 most fashionable foliage is reached around well lit and shiny evident household leather when it comes to vivid, smart tones such as elegant white, neon renewable together with campfire powerplant crimson. Create intonation in rubbed silver or gold, does not directly in trend for your summer event.
Simple thong variations incorporate cut-out together with embossed moist cloth by using often level soles and also lower blighters that will be a wonderful choice for days out and about as well as from the shopping mall. Nice, athletic appearances showing heavy-duty connectors with stitched webbing are widely used, though the colorings get their sign from that summer's brilliant taste buds. Designed for dressier don, seek thong design new sandals by means of teeny posting bounders and thin digits ties, frequently sparkled by way of shimmer together with rhinestone. Iron wedge bottoms are back just as before, too, however you are extra woman's at this point. Cork was in yet it is frameworked during clair household leather to accommodate the particular uppers, making a dazzling fashion fact.
All the things Previous is completely new Once again
Very easy have much older or simply better compared with gladiator shoes. You are able to be cautious utilizing ankle great gladiator sandals resorts, and move mad with the hippest looks strutting about the runway over the summer time of year. Bright and vivid hues combine with aluminum groups or sectors involved with moist cloth to have a rough outdoors seem, techno appear this really is certainly not old-fashioned. Makers have got latest great ideas on your gladiator seem having uncommon resources and also some unattractive lamps want 100 % organic cotton canvas and even boot eyelets lacing all the way to mid-thigh. Try a better glance together with Goth-style gladiator pitching wedges desinged to use industrial appliances and then companies, or simply aply very thin obvious leather-based band as a result of coils to brew a fragile ballerina glance. If you cannot get goofy in the summer, anytime on earth do you?
Slideshow in addition to Mules as well as Bestial Photos, My dear!
Accommodate is undoubtedly cool not to mention toes clothing is focused on new sandals who are best for the feet. Naot and Our planet either feature popular sandals through harmful shoes not to mention molded soles this promote good posture as well as nutritious wandering. On the other hand, remaining match isn't no more than valid reason to make sure you recommend healthier sandal styles. Unusual paper prints and shades fit style for the an elemen by using fitness and luxury. May, critter patterns abound, like on the vamps and additionally uppers with among the most more comfortable flip flops actually manufactured. For the reason that high heel mules in addition to glides present minimal in terms of service as well as steadiness for your paws, the only real and additionally insole structure is vital. If you decide on a pair of this year's most desired health and fitness sandals in jamaica, be sure you pick a two within one on the superior companies to help you go with superior quality material, excellent fabrication and then plancher that produce the toes feel as if nirvana.
Whichever sandals jamaica resorts you finally choose pertaining to the hot months have on, make sure that you prevent your tip toes in top condition just for exhibiting through occasional exfoliating along with calming rub having ft . creme at least once each and every day.
Resources
[url=http://contrs.com/vb/showthread.php?p=1554131#post1554131]Australian Sheepskin Boots Arouse A Lasting Effect In The Fashion Footwear Globe[/url]
[url=http://clubblasian.com/newreply.php?tid=150128&load_all_quotes=1]Techniques to Care For Low-priced UGG Boots[/url]
http://www.gaffmasters.com/blogs/
http://southfloridabusinessnews.com/new/blogs/7662/112057/bailey-button-fancy-5809-in-whic
http://beforeitsnews.com/alternative/2012/10/athens-anger-greek-police-rhetoric-reminds-of-military-dictatorship-2477786.html
http://costoflife.ning.com/group/fox-fur-5685-calculate-from
