I am using the following steps (on a sample piece so far) to get a nice mission oak appearance on quarter sawn white oak.
Step 1 was to apply a base stain/dye
Step 2 was apply shellac
Step 3 was sand the shellac lightly
Step 4 was apply an old english gel stain and work into the pours (also from Minwax)
Step 4?5 Do I sand here at 320+, or with WetDry or use steel wool OR NOT sand at all
Step 5 was to apply a top coat of wipeon-poly from Minwax
My question is.. between steps 4 and 5 (gel stain to poly) should I lightly sand the gel stain coat. I did on a sample, but it really dulled the appearance and even after 2 coats of the wipeon poly, It appears to be duller than I had anticipated. I used 400grit wetdry paper with water at this set and if definately killled the luster from the gel stain.
The wipeon poly restored some of the luster,, but not all. Other wise, this process worked well and gave me a beautiful finish to the oak.
What are your recommendations, Thanks in advance
RichD
Rich,
After you apply the stain there is no need to sand or rub it with steel wool.
Just let it dry well (use your nose) prior to top coating and you should be fine.
Let me know how you do.
Peter
