hello all, I am building a set of cherry kitchen chairs. Not sure of the best way to attach the seat. (solid cherry) Not looking for the easiest method but the best. This is my first chair and want to do it right. The chair is simple; all right angles, and mortise and tenon joints. Any suggestions would be greatly appreciated.
Thanks mike
Edited 7/3/2002 3:41:27 AM ET by MIKEHAINES
Mike,
It would be helpful to know what kind of seat you're talking about here. Solid wood, upholstered, woven? A few more details are probably needed to give proper help.
Scott
thanks for your response. I am making the seat out of solid cherry.
No one's jumped in, so...
My suggestion (mind you, it's only a suggestion, I don't want Clem to come back online and call me a boob for giving bad advice) would be to treat it like a table top. I would screw it from underneath (either through the stretchers with a countersunk hole, or with a pocket hole inside) in the center of the seat to make sure it isn't going to come off. Then I would use wooden buttons on the outer edges of the seat to attach it to the other stretchers. This would like it move with the climate/seasons.
I imagine you could just screw it all the way around. I've seen that, but personally, I wouldn't as that doesn't give enough for seasonal movement in my opinion.
Of course, it again depends entirely upon your design.
Scott
I have had good luck by cutting blocks to fit into each corner of the chair (where each leg is joined). I glue or screw (or both) to attach these blocks and then drill a hole significantly larger than the screw I intend to use to attach the seat from below. I then find a washer large enough to cover my large hole. This arrangement allows the screw to float in the hole thus allowing movement, but also hold the seat securely to the frame. I find this difficult to describe with words, wish I could draw it for you.
Wayne
thank you for your responses. I was thinking that screwing down the seat would work but was not sure if it was the best method. what do you think of tenoning the seat with a dowel. What would they done in the past. thanks again mike
