Material to prevent rust in sword case
I am finishing up some sword cases and have a question regarding corrosion. I will be supporting the swords on wooden bridges that I would like to line with some type of material but am concerned about trapping moisture and rusting the swords. Does anyone have any recommendations? Silk, felt or just apply some shellac and leave it alone?
Tom
Good darn question. These are my best guesses:
Would waxing the swords work? What about some of the protective spray we all use on our shop's cast-iron surfaces? Or hiding some of those silica beads in the case?
I had not thought of the silica packs. I may hide some in the bridges.
Tom
Tom,
I use Camelia oil as a rust preventor with my steel tools. I believe it is traditionally used in Japan for protecting all manner of blades -certainly plane blades and chisels.
The oil is very light with no stickiness.
Thanks, that would be a good suggestion to pass to the client. I am not overly concerned about corrosion as the case will be in a conditioned environment but I did not want to introduce any problems. He spent a few grand on these so I am sure that he would be happy to buy a small bottle of camelia oil to further protect them.
Tom
Edited 10/30/2008 2:24 pm ET by G Hepplewhite
You may want to saturate the wood with the camelia oil at the point of contact. Walnut oil works too. Re-apply as needed. That'll help keep the wood from absorbing humidity from the air.
Mike HennessyPittsburgh, PA
At one time you could purchase a felt-like material at fabric stores that was designed to go in silverware cases, to prevent tarnish. I'm not sure what the fabric was treated with, or how well it would work for your needs, but it bears researching. As I said, it was sold in fabric stores, by the yard.
Woody
HWG,
The popular brand was called Pacific silver cloth.
Do you happen to know if that's the same thing as FlexZorb? I use that in a display case for silverware (works pretty well) but can't find the cloth retail anywhere.
Jim
Jim,
Not familiar with the product you named. I got Pacific cloth thru a jewelry store. How much are you looking for?
My wife is the one who wants it. She's got so much jewelry (including a lifetime of peace offerings) that a bale or two might suffice. I googled it and found a couple of good sources in the US, which I'll pass on to her. Many thanks,
Jim
I'd line the bridges with hide from a British comedian. That should keep things dry enough. ;-)
Japanning the blades?
I know some Japanese colleagues who collect antique samurai swords which are kept on wooden stands. They regularly (like at least monthly) wipe them down with camellia oil after carefully wiping them with very clean cloths. They only handle them with cotton gloves.
If I were you I would find out from the Keepers of these Swords about the correct Material to Employ for the Job.... They will know, and no substitute will do, otherwise the Well Being of said Swords will be Jeopardised.Trust me- Keepers of Swords are a fanatical and mystical lot, much given to strange rites and practices in the dark hours.
Apart from this, and to gain added insurance, I would be sure not to use a wood containing too much tannin, such as Oak, which will cause any Sword made of non stainless steel to take fright even if wrought of the finest Japanese forged steels steeped in tradition and blessed by one thousand priests. And you could locate some bags of Silica Gel dessicant granules somewhere out of sight, but this too would require permission from the Head Sword Keeper. I would even enquire as to the most favoured species of wood to use.
philip..
To add to you post
Tea seed oil (also known as tea oil or camellia oil)
http://en.wikipedia.org/wiki/Tea_oil
Yes, but is this approved the Imperial Brotherhood of Sword Keepers? And if so under what conditions should it be applied? (;)Philip Marcou
I would think after you drank the tea?
You got it....Philip Marcou
Camfor placed in a closed display case will avoid rust.
Philip
