Looking for advice on finishing a long grain maple butcher block table. The legs and apron are cherry. Have read through the archives, and saw a lot of different approaches. A demanding use of the finish to say the least(lots of abuse,durability, and ease of repair)I am looking for a more natural look than a thicker coating
Any advice appreciated
Paul
If you have the capability to spray you cannot beat SW precat lacquer. With that said, if you don't spray I would use a quality varnish(not poly)Behlen's Rockhard or Prat&Lambert thinned 50% with mineral spirits and applied with a lint free rag. Sand between coats with 320-400 and build the film you are happy with. I would use at least three. You can use a water based product if you don't want the amber tone of varnish,but water based finishes are very bland looking IMO.
I would say that for a wipe on varnish (the thinned varnish referred to) you need at least 6 applications for an adequate finsh, particularly for a table top. In my experience (and I often tell people using it for the first time), the first 2 or 3 coats of a wipe on do not really look very good and you must perservere and add more. It is also not necessary to sand after each applicaton--about every third one is fine. Gretchen
You forgot to to tell the most important sanding is the first coat. Sanding after the first coat of finish knocks down the bulk of the fibers that stand up after the initial coat. I agree that three coats is a little light, but he was looking for a light film build. Stop when you achieve your appearance goal.
Thanks Gretchen and Terry! What do you think of Waterlox? I had read an archived thread that someone used it on a table and it dried soft and sticky and newsprint imprinted on it. I would not think a floor finish would do that. I have used the sealer/finish before as a sealer and to pop grain, and really like the product,but never used it as a finish.
Thoughts?
Paul
I think the person made some sort of mistake. The Pratt&Lambert 38 is a lovely non-poly varnish also. I haven't used Waterlox, but know lots of folks here have. I like a satin finish also, but that will be your decision.Gretchen
Was just reading some other posts while you were replying Gretchen, and i think you are right. I am a satin guy too.
Paul
