I am getting ready to lay laminate flooring in my living room. One of my next projects is to build an oak fireplace mantel and surround, but I need to do the floors first, as this project is well on its way.
I have read a book about building mantels and it specifies mounting the mantel onto mounting blocks attached to the wall, so the sides no not need to support any weight on the floor.
My basic question is: When I install my floating laminate floor, should I leave space for the mantel sides to go below the top surface of the laminate (in other words, should I cut the laminate around where the mantel sides will be?)
Not necessary. You're putting in a hard surface floor. When you build the mantle, set it on the floor. If you have to adjust and shim for level, at least one leg can sit on the floor. I dont know what your design is, but any minor irregularities in the floor can be easily dealt with - base shoe.
Also worth noting, mantles don't carry a lot of weight, but they can pull loose. The mounting blocks you place on the wall, try to hit a stud. If you cant, take the time to put some toggles through them to hold things. Construction adhesive isn't bad either. Having the mantle shift and leave a 1/8" gap a month down the road can be very aggravating. If it does happen, that can sometimes be remedied with cabinet scribe, but its better not to have to.
Also make sure your distance is within code. Different FPs have different distances they must be from combustables. Most direct vent units are around 6".
"The child is grown / The dream is gone / And I have become / Comfortably numb " lyrics by Roger Waters
