Just wondering if anyone has any information about how to make your own wood putty. I was hoping to make my own so it would match exactly, and hopefully take stain with out any noticable flaw. Please let me know if anyone has a solution. Thanks.
One way is to collect really fine dust from sanding the wood you need to fill and mix it with boiled linseed oil or tung oil, depending on how the piece will be used. Mix it into a paste(not too dry- experiment) and fill whatever you need to. It may end up a shade darker than the solid wood but will be a lot better looking than just about all of the other fillers on the market.
For dark woods, I've had some success mixing the fine sawdust with just enough dark carpenters glue to make a paste and using it like a filler. Let it dry and sand it smooth.
Whatever you try, experiment on some scrap first.
Thanks for the information, i will try it soon. have you had any problems staining with this type of formula? or should i use another approach with stain?
I've had decent luck by staining before filling then using those wax 'crayon' fillers to get my color match. Sometimes, I have to mix two colors to get it right. I dab it in the hole and wipe it smooth then apply my finish.
I agree with Dave, stain first, then fill. I use a "burn in" stick that is melted and leveled off. Follow that with powdered Blendal stain, and you get a good color match.
Wirerat,
Mixing Shellac with sawdust works well.
The latex putties can be tinted by mixing different colors together, or adding tints.
Often I'll use a putty that's a close match, then use my collection of brown pencils to color in the area to match as close as I can get it. Pencils are good because they permit drawing in grain patterns.
Using your saw dust from the project is the best way to get a match. I normally use what ever sealer Im using as the top coat. By using the same sealer, will insure you have a perfect match. (shellac, poly. linseed oil mixed with varnish... doesn't matter)as far as color gos.
that sounds good, ill try that
I use the dust from the wood I am using and mix it with 5 minute epoxy.
wirerat-- I think sawdustmaker is on the right track-- I gave up ontrying to fill any voids until my 3 rd coat of Deft- by then you have achieved the near finished tone (color ) in other words there are only a few woods that get darker. like cherry and you can even go a little dark on the shellac stick if you want to stick your work out in the sun a few hours There is a big help If you have Mohauk 's latest addition , a selection of rub-in sticks to sort of finish of your filling job and when you have done as much of it as I have ,the flaws will 99% disappear Granted it will take patience and perseverance but well worth it. BTW I cut Semi deft one to one and use a single stage HVLP there are other goodies that would help you but you have decide what you want to do
