Current project is a demilune table. Went
to the local woodcraft store to get more
mahogany. Only saw african mahogany in the
wood bin area. Ask the clerk and he said
that they were unable to get any honduran
mahogany. The table legs were honduran
mahogany. At any rate, I applied an 1/8″
thick layer of the african mahogany to the
table skirt. Comparing one of the legs
to the table skirt, there seems to be
significant difference between the 2 pieces.
See the attached picture.
Is this just normal inter-species color
variation? Or is african just somewhat
lighter than honduran?
Jim
Jim ,
The African is another species type all together , it's called Mahogany but maybe not actually a true Mahogany such as Honduran . The basic grain patterns can be similar but the African has a lot of broom grain and obviously there is a color difference in this and many cases .
Try and find more Honduran if you can , it looks like a beautiful piece you are making don't let a few pieces of wood stop perfection.
good luck dusty
Thanks for the info on African mahogony...I bought a board locally, not knowing anything about mahogony. I then ran across some plans for a footstool that had through tenon joinery and legs at a 10 degree angle...more challenging than it looked. The mahogony was a lot softer than I envisioned, closer to cedar than walnut, and chipped out badly on the backside when I chopped out the mortises...thankfully the chip out is hidden by the tenon shoulders...overall I can't say that I like African mahogony much.
Neil
African Mahogany is not worth the cost in my opinon. I would get more honduran. Just remove the apron and re veneer with honduran.
If you dye the apron and not the legs they will color differently. The honduran will be a lot darker than the african in about 1 year. And they will continue to change at not only different rates, but to different colors.
Check out irion lumber. http://www.irionlumber.com give them a call, let them know what you are making and they will get you the right piece(s) of lumber.
Also I made a Demilune table at the Olde mill cabinet shop in a class with Steve Latta. He used the table from FWW 180 as the demo for the class. And he buys his wood from there and trusts them to pick his wood so they are familier with the wood needed for the tables.
And not to be critical, but the flower in the oval at the top of the leg is upside down.
Well...I'm not sure if I want to strip off the African mahogany
and replace it with Honduran. I really like the bolder grain in
the African...but...maybe. It probably would be a challenge to
get the stain on the African and Honduran to the point that
the coloration would be very close.I didn't realize that the oval emblem was upside down. I just
assumed that the acorns were supposed to hang down below the
leaves on the plant in the emblem?This is my 2nd table of this type. The first was a copy of the
table that Steve Latta built in the Nov/2005 issue of FWW. It
turned out so-so. I had trouble morticing in the hinges on the
table top that folds up/over. So I decide to follow the same
basic plan this time, but just build a demilune type table.
That means no folding top and the legs attach differently since
there is no gate leg in the back. I also used ebony feet for
the legs instead of using a black(dark) stain on mahogany.
Gives a bit more contrast. At any rate, I enjoy sort of making
it up as I go along. The thing I like about this table is that
it involves a number of different woodworking skills.Jim
Just to clarify a few points about mahogany and mahogany:
1. "African mahogany" is not a completely different wood than "Honduras Mahogany." They are not exactly the same species but in the same family.
2. "African mahogany" is not softer than "Honduras mahogany." Actually, "African mahogany" is comprised of four related species, two from the jungles and two from the drier areas of west Africa. The two from the drier areas are harder than Honduras mahogany. The two from the rain forest, well, it depends. Generally, they are harder than plantation mahogany but softer than the traditional honduras mahogany.
3. Yes, chip out is a big problem with African mahogany because the grain is quite different from Honduras mahogany. While the honduras mahogany usually has a wonderful, easy grain to work with, the African has a lot of interlocked grain--that is, one year the tree grows in a spiral to the right and the next year it may reverse and grow in a spiral to the left. Thus whether planing or chiselling, you're often getting tear out.
4. I don't know whether the African is generally lighter than the Honduras. I have some smaller pieces that dyed identical. But I do know that the African is much more variable, sometimes having streaks that are almost a light tan/grey colour.
Jim-
African mahogany is nothing like Honduran, it is much lighter and color and quite a bit softer. Some of it smells like a monkey cage when you cut it. You will also find a prisma of colors and inconsistencies in grain.
By the way, your plane irons will stay sharper longer if you don't lay them down on a cast iron top. IMHO.
Sean
Can you reword ####significance?
Not sure what happened on the "xxxx" deal. Some sort of fat fingered
problem I guess.Well...I dug up a can of "colonial oak" gel stain from the shelf and
applied it to the african mahogany on the table skirt. The color of the
table leg and the skirt are now closer. I think I can get them even
closer by additional judicious application of this stain to the skirt
and legs. New pic attached.Jim
Sometimes the system will insert #### in place of a bad word or what it falsely perceives to be a bad word. This seems to be neither. My wife is very good at matching colors. I am not and unfortunately she is not a woodworker but it seems that a little more grey or black is in order. Have fun
I guess the ultimate solution is to get all the wood you need for a project at the beginning to make sure it all matches. Even then you have to carefully compare each piece to the next to make sure they're compatible. If you have to go back and get more, make sure you take a sample with you. Better yet, if the dealer will let you, take some mineral spirits or alcohol (not Jack Daniels) with you and wipe a little on each piece to approximate how they'll look with a finish on them and compare them.
Staining the piece could even things out, I suppose, but if the woods are too dissimilar to begin with, it still won't look right.
