Can someone explain how to make the curved crown moulding at the top of a Louis XV armoire? I have an entry closet that I want to make look like a built in Louis XV.
Miterhead
Miterhead
Prepare a curved blank and start carving.
I have done this by using 1/8" strips, each cut to the profile needed and then laminating them togeather using a form made out of stacked plywood laminations in the correct shape. Pertty complicated. I recently used this method to make the equivelent of a crown moulding but used as the to of a king sized bed headboard.
I think it is issue #166 where Phil Lowe explains using a router and several different bits to cut the profile in a swan neck pediment moulding after he cut the desired shape in solid stock.
How big is the moulding? What type of curve?
J.P.
Without knowing precisely what you are wanting, I will take a guess that you are wanting something that is more sculpted than linear molding.
Start with thicker material, then band-saw the blank to shape, then using a right-angle grinder with a chain-saw tooth blade, do the rough bulk removal. Replace this with the coarsest grit disk, which will help you fair the contours, follow this with a finer disk, follow this with progressively finer grits on a random-orbit sander.
Go for it man. It is easier than you think.
