Some days it just happens…
Im building the face frame for a cabinet…not complex. Cabinet is 72 wide, 30 high…
Frame is 1 1/2 wide rails and stiles…
Opening inside dimention then is….27 by 69…
there will be 4 doors…so i need even spacing of all 4 openings.
After 5-6 tries to get that figured out…I gave up, went to the house, and now Im looking for my brain…if you see it…Ill pay the postage.
ChiefsFan,
Assuming that you will use 1 1/2" wide stiles between the doors, here's how I would calculate the openings. The cabinet will require three stiles between the two outer doors, so 1 1/2" x 3 = 4 1/2". The opening is 69" minus 4 1/2" is 64 1/2" of width available for the 4 doors. Divide 64 1/2 by 4 and the resulting 16 1/8" is the width of each door opening.
Hope this makes sense.
jon
