Hello All,
Being fairly new to woodworking, I have been actively looking for a good local club to get involved with. Having lived on the island of Oahu for a couple of years, I find this to be an evasive endeavor. Hawaii is rich in local artists, but I can’t seem to find a club or classes with the resources that I need (besides the local Woodcraft).
Is there anyone out there that might be able to point me in the right direction? Also, is there a national or international club that might accomplish the same thing for me? Thanks in advance to anyone that can help.
-Dave
Fine Woodworking Recommended Products
Chicago Electric Belt Sander
Weight: 7 lb. Amps: 6 Variable speed: Yes Belt alignment: Good Material removal rate: Fair Sanding flatness: Very good Shaping/scribing: Good Handling on side: Very good Dust collection with hose: N/A
Delta 22-555 Planer
Knife changes on this planer were easy enough, except that you need an Allen wrench to open the dust cover and gain access to the knives, and it’s not the same size as the wrench used to loosen the screws that secure the knives. The 2-1/2-in.-dia. dust port can be reversed for use on either side of the machine. Two material rollers on top of the machine aid with transferring stock from the outfeed side back to the infeed side. Finally, there is no gauge that indicates how much material you’re about to remove, a convenience that three other planers also lack.
DeWalt 734 Planer
One of only two machines with a cutterhead perfectly parallel to its beds, the DeWalt 734 is a very good planer. Knife changes overall were straightforward, but access is difficult because you must remove a Phillips-head screw from under the dust shroud—not an easy task. The dust port on the back of the machine has a 2-1/2-in.-dia. opening but can be hooked up to a 4-in.-dia. hose. Connected to a dust collector, it did an excellent job gathering chips. And because the port exits to the left of the machine, the hose is never in the way of exiting boards. The top of the machine is flat, making it a good place to stack boards between passes.
Festool TSC 55 KEB Track Saw
This saw is nearly identical to the TSC 55 REB, with two main upgrades. The first is a thinner blade that cuts quicker and extends battery life up to 40%, according to Festool. The second is the headline-grabber: an anti-kickback device that replaces the riving knife. The KEB is compatible with older Festool tracks and batteries. You can buy just the bare tool, the tool with the batteries, or the tool with the batteries and a 55-in. track.
Matter Hackers MH Build Series PLA Filament
MH Build PLA is an affordable PLA filament intended for producing quality, 3D printed parts. MH Build PLA comes in a wide selection of bold colors to choose from. MH Build PLA is made with price in mind for any maker, from beginner to advanced, in a wide selection of bold colors.
Maybe this will help:
http://www.mauiguild.com/
Ruth Dobsevage
Taunton New Media
Thanks for the info. It looks like a good starting point for me.
-Dave
