I am making some cabinets that will be used for photos. They have a face frame and glass doors. I would like to install some lights in them. I was hoping ot find some sort of strip light that can be mounted on the rear of the face frame. If the could plug in and have a switch either on the cord or a small switch inside the cabinet that woudl be great. I’ve seen some Low voltage ones but then I have a transformer to deal with and I don’t have anyplace to hide it. Any suggestiosn?
Dana
I use rope lighting for this sort of thing. You can get it in fixed lengths at Home Depot, or you can buy the parts (lights, connectors, etc) on the internet and make up whatever you need. Do a search for "Rope Lighting".
I'm doing the same thing for accent lighting in kitchen cabinets, close to the ceiling.
I found 110 volt strip lights at (whisper) Lowe's. They come in 10, 20 and 30 inch units, 6 watts per 10 inches; they plug in (or you could hard wire) and include an inline switch you can add if desired. They're about 1/2" x 3/4" and screw on.
kreuzie
Thanks, I'll check them out. The rope lights I found seem about right but I haven't found an easy way to switch them so the inline switch sounds good.
Dana
Dana,
FWIW, for accent lights I would look to what has already been said but for use with photos, or any other flat reflective glass I would use caution and experiment with where your think the placement should be. In the face frame could be disaster as the light may bounce directly back at you. Most lights are placed above and pointed down for that reason.
Angle of acceptance = angle of reflection.
BB
Good thinking! I thnk it is going to end up beign some sort of Rope light. I still have to figure out the switching. I will mess around with the rope light and see what I can come up with.
Dan
Dana,
Lee Valley makes an incandescent cabinet light that sells for less than $10. I've used them before and found them easy to install and use.
http://www.leevalley.com/hardware/page.aspx?c=1&p=40201cat=3,43629
Jim
Thanks, I wonder how hot it gets? I know it says it can be used in closed cabinets but mine is only 2 12" deep on the inside of the face frame. I would worry about the bulb being to close to the back.
Dana
Dana,I think you're probably right. I'd go with the rope lighting with a case that shallow.Jim
Just a couple of cautionary notes:1. Test the colour of whatever light you decide on. Do the photos look good in it? You might have a poor colour rendition because of "missing colours" in the light source.2. If the photos are ink-jet prints the colours fade with exposure to light - especially the red - so you may want to consider a timer to turn off the lights.
