Hi John,
I seem to remember a video you made showing a unique way to build a tapering jig for legs, but now I can’t find any reference to it when I need it. I think this is a picture I caught from the video.
Can you help?
Bill Antonacchio
Good question...
Hi Bill,
That sure looks like John, our shop floor, and our tablesaw but I can't find reference to that video anywhere.
All John's videos should be listed here by paging through all these articles: https://www.finewoodworking.com/Gallery/GalleryResults.aspx?RelatedAuthorID=1277
Maybe it was embedded in another video? In one that relates to tablesaws? See full list of JWs videos below.
Gina, FineWoodworking.com
Folding a Bandsaw Blade
with John White
It's trickier to explain than it is to do, so watch!
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5206
How to Uncoil (and Recoil) a Bandsaw Blade
with John White
Watch a technique that works nearly every time.
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=31409
Fast Fix: Build a Hinged Stop Block
with John White
For repetitive crosscuts on the tablesaw, nothing beats this simple solution made from shop scraps
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=33241
Make Your Own Tenoning Jig
with John White
Save money and cut precise joinery with a shopmade tablesaw jig
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=32544
Shopmade Stop-Block System
with John White
Craft a simple tablesaw jig from scrap plywood to get repeatable cuts for furniture parts
https://www.finewoodworking.com/Workshop/WorkshopArticle.aspx?id=32519
A Super Sturdy Fence for Raising Panels
with John White
Fast and safe panel raising with a shopmade tablesaw fence
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=32543
Rabbeting Fence for the Tablesaw
with John White
A clamp-on auxiliary fence that's perfect for cutting rabbets
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=32535
Simple Circle-Cutting Jig
with John White
A quick-to-make jig for cutting flawless circles on the bandsaw
New-Fangled Workbench, Revisited
with John White
Take a look at this well-engineered workbench that's as versatile as a Swiss Army Knife.
https://www.finewoodworking.com/Workshop/WorkshopArticle.aspx?id=28530
Build a Simple Miter Saw Stand
by John White
This simple miter saw stand solution is great for tight spaces and even tighter budgets.
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=33190
How to Handle Large Sheets on the Tablesaw
with John White
John White shows how to use a long bar clamp as a handle for guiding large sheets on the tablesaw
https://www.finewoodworking.com/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=31001
How to Adjust a Jointer
with John White
John White shows how to fine-tune the height of a jointer for perfectly straight cuts with no snipe
https://www.finewoodworking.com/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=31033
An Easy Way to Check Tablesaw Alignment
with John White
John White shows how you can ensure that your tablesaw blade is parallel to the rip fence
https://www.finewoodworking.com/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=31002
Assembling a New Tablesaw
with John White
Find tips and shortcuts for assembling a box of parts into a well-tuned shop tool
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=25283
The New SawStop Contractor Saw in Action
with John White
See us put the brakes on the blade and get a tour of the machine’s features
https://www.finewoodworking.com/ToolGuide/ToolGuideArticle.aspx?id=30456
Safer Cuts with a Riving Knife
with John White
This important safety aid is just recently showing up on tablesaws in the U.S. as an alternative to the more common splitter
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=26215
Jointer Knife-Setting Jig
with John White
Make this jig to set jointer knives with little fuss
https://www.finewoodworking.com/Workshop/WorkshopArticle.aspx?id=5294
A Versatile Sanding Station
with John White
A rolling cart features a downdraft table and shop vacs to collect the dust
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=29793
Set the Tension on Your Bandsaw
with John White
A shopmade jig will help you set the tension on the blade
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5295
What to Look For When You Buy a Bandsaw
with John White
Learn how to evaluate the models before you close the deal
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5192
Using a Circle Cutter
with John White
Cut accurate holes and the discs to plug them up
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5193
Testing Biscuit Joiners for Parallel
with John White
A dial indicator tells if the slot is cut parallel to the face of the workpiece
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5189
Replacing Router Brushes
with John White
A router with badly worn brushes won't run well; here are some maintenance tips
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5190
Listening To Tools
with Aimé Ontario Fraser, John White
The sounds your tools make can tell you a lot about how they're working
https://www.finewoodworking.com/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=5246
Bandsaw-Tension Handle Extension
with John White
A quick fix for an awkward problem
https://www.finewoodworking.com/subscription/ToolGuide/ToolGuideArticle.aspx?id=5203
Bandsaw Table-Tilt Fix
with John White
A technique for quickly adjusting the tabletop to frequently used positions, both forward and back
https://www.finewoodworking.com/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=5195
A Jig for Tuning Your Tablesaw
with John White
This mounting block for a dial indicator helps ensure an accurate setup
https://www.finewoodworking.com/subscription/Workshop/WorkshopArticle.aspx?id=5296
Hi Gina,
I am sure it was a separate very short video. I watched it and captured that image from it. Thought that would be sufficient to make my own some day.
Now the day is here but I have a few questions.
By the way I did that search too, that is why I posted the question for John.
Thanks anyway!
Bill Antonacchio
Lost Video
Bill,
Can't seem to turn up the jig video but it is very simple. Rip a board as a base for the jig and leave the rip fence in place. Next attach blocks to the base to position the piece you want to taper so that the cut line on the workpiece is directly over the ripped edge of the base, then just run the rip cut again trimming off the overhanging edge of the piece you want to taper.
Hi John, Based upon the
Hi John,
Based upon the image I posted I went about mocking up the jig for a taper on the legs in Tim rousseau's cabinet project.
My question and reason for concern is the short length of the taper hence the steep angle. When I placed the blocks and a long back support for the leg it still seems a liitle unsteady. Even tried reversing the whole setup on the base board and looking at the cut with the force coming from the opposite direct it seems a little unstable.
Could you just lay down a 1 1/2 x 1 1/2 leg with a short steep angle taper and see what I am talking about? I attached two crude jpg showing both directions, but is there a better way?
Bill Antonacchio
It probably needs clamps...
Bill,
If the leg seems unsteady sitting on the jig you will need to clamp it down. Put a scrap the size of the leg stock on the jig along the back edge of the leg behind the block that positions the leg. Now place a short block spanning the leg and the scrap piece and run a screw through it into the blocking pulling it down against the leg blank and the scrap. One or two clamps should tie the leg down securely.
