I’ve got leftover t&g oak flooring with chamfered sides . I would like to use it for furniture. Any ideas? If I made a table, would I need a sub-base? Maybe I should rip off the edges and use the remainder? Thanks, Todd
Still looking for ideas. Thanks. Todd
toddhunter,
I just put the last coat of Waterlox on a mission style desk for my daughter. I made it out of flooring material. The attached pic is not my desk but the desk I copied....mine is prety close...I have a single draw..36x28x28h she did not want it too big....just a thought
Edited 7/29/2004 1:24 pm ET by BG
BG, did you just glue the t&g like any other edge gluing surface? Todd
Todd,
I squared up the stock(about 3"w x .7 thickness), planed it and glued up to make a panel....three boards at a time. I made the top a bit large and with the waste from both sides, I resawed and glued an extra 1/4"x 1" strip to make the top look thicker...and then used (about) 1 3/4"x1" breadboards on the end.
The legs could be a glue up from your stock...and also the aprons. The slats were resawn and planed. Hope this helps clarify
I built the table in the attachment from Birch flooring I had left over from my living/dining room. I squared the edges and glued it up. I doubled the edges and made breadboard ends. Polyurethane finish. This has been our kitchen table for 12 years. We beat it up and it still looks good.There are more old drunkards than old doctors. Ben Franklin
Chees Blue it looks great!
Old/excess/spare/recycled floorboards are surprisingly common. And often of surprisingly good timber. Maybe there ought to be a prize (or, let's start a wee contest right here) for the most imaginative use?
Kiwimac,
Nice pun. I realized after I posted the photo that the floor under the table is the exact wood I used for the table top. I'm glad that project came to fruition, Kiwi.
BleuThere are more old drunkards than old doctors. Ben Franklin
I recently used Walnut flooring for an entryway table / cabinet. I did mill off the t&g, and I had to work around the bottom sides being grooved, and there was the thin issue ... but it was beautiful wood. See no reason you couldn't use what you have, working around the obvious constraints.
Great suggestions. It gives me just enough confidence to move forward with a project: to be determined.... Todd
My woodworking dad recently built a kitchen island for my sister. It had a butcher block top, but the cabinet sides were paneled with T&G. It matched the floors perfectly, and helped keep the island from looking out of place.
Dan
Cajun Dan,
Can you post a picture of the island? I am in the process of building one and would like some ideas. Thanks.Regards,
Buzzsaw
Buzzsaw,
I will try but it might take some time - Dad lives 300 miles away and does not have a digital camera.
I will describe it as best I can:
The top is a red oak butcherblock with a decorative tile inlay. It is about 4' X 3'. THe base is about the size of a kitchen cabinet with a pair of drawers and doors on one side.
The sides of the cabinet have T&G panels running vertically. I think they are attached to a plywood substrate. (I was not involved in the construction, so I can only say what it looks like.) I am pretty sure he did not just panel over a HD cabinet, since the kickpiece runs all around the bottom.
I hope this helps.
Dan
Thanks Dan,
Did he keep the T&G on the panels and attach via the T&G? I keep reading where people are cutting off the tongues and I don't see why.Regards,
Buzzsaw
No need to cut off the tongues. It would ruin alignment.
D
OK,
Another dumb question. Are you gluing the tongues into the grooves or are you using nails as you would installing a floor? The reason I ask is because I actually picked up a few bales of pine T&G that someone used for their walls and I was wondering what would be the best way to attach them. Maybe they would just float in the groove?Regards,
Buzzsaw
TODD, Friend of mine built a coffee table usind #1 grade oak t&g
He oriented all the boards standing up and just glued them up after planing off the tongues. Mitered the corners and bread boarded over the end grain sides
( NO power tools either. )
I once sliced up some walnut stair treads and made enough parquet blocks to cover two window seats .
All the 'blocks were chamfered on four sides Marvelous!
Steinmetz
Standing up? Do you mean on edge (liike a laminated workbench top) or on the ends (end grain up like an authentic butcher block)?
TODD, Laminated with the grooves at the bottom (tongues planed off).
Stein
Table top 2-1/4" thick legs built up from 3 lengths of flooring
Todd, I just made a pretty cool sunburst headboard for a bed with left overs. I used a piece of 1/2 ply for the backer and glued them on with PL-4000. I trimmed the pieces because of the sunburst effect I was trying to achieve. It only took a couple of days to complete. I used the PL because I had a bunch of it left over from a siding job I did a few months ago. It worked fine but probably wasnt the best choice.
Sincerely;
The Tool Guy
