Largest Bearing-Piloted Router Bit Avail
Does anyone know of a flush trim bit with 2-1/2″ or greater cutting length? I found this 2″ bit.
http://www.rockler.com/product.cfm?page=11083
I suppose I could make one cut then adjust depth and use the cut surface as the guide. Will this yield a no-cut-line-surface, or is their even a slight difference in bearing diameter and cutter diameter for these types of piloted bits?
Greg
Exo 35:30-35
Edited 5/21/2008 9:16 am by Cincinnati
PRC has such a cutter. CD = 1.125", C.length = 2.5" with long 1/2" heat treated shank.
Only for those with a long list of priors; this cutter is not for the inexperienced.
Just a few.
http://www.routerbits.com/cgi-routerbits/sr.cgi?1211394502_20560+47
http://www.routerbits.com/cgi-routerbits/sr.cgi?1211394502_20560+37
http://www.routerbits.com/cgi-routerbits/sr.cgi?1211394502_20560+98
Excellent quality and decent price. Probably the best bit maker in the business.
F.
