just learned that laminate comes in different sizes for counter tops as well as for other projects.
I am doing my router table top. When I tried to buy the laminate, the salesperson asked me what thickness do I want as well what the application would be. So, as I was not experienced with laminate, I just mentioned to him just give me the usual that is used for countertop. At the last minute, I changed my mind as the price varies greatly based on the size thickness and grade.
Can anyone recommend the best for my application of router table top.
Thank you,
Moataz.
Often laminates come in two thicknesses one for flat surfaces and one for surfaces with sharper curves I think this grade is called postforming. For a router table I would use the thicker type. Of course there are so many brand out there now you have a lot of choices.
Troy
I just bought the off the shelf stuff at Lowes. I haven't had a problem.
Webby
Yes the difference in thicknesses are for standard countertops or thinner for "Post Forming" As far as sizes go, usually 4x8,4x12 ,5x12 I have purchased Backsplash size-24"x12' if going with full height backsplash. Either way I was always charged by the sq. ft. so it doesn't matter price wise what size you are getting. Just make sure that you can handle the roll. It must be supported while cutting.
