Hi all,
I am from Melbourne Australia,and am seeking advice on fitment of ceramic guide to European Model GM620 HolzProfi 25 inch bandsaw. I am using machine to cut planks from green timber and having difficulty with bearing guides failing due to resin on blade.
From what I read the Laguna ceramic guides should do the job.
Could anyone of you good folks offer this old salt some advice?
Mountainrider
g'day mate,
I have a Laguna bandsaw, and their ceramic guides work well, though any ceramic guides would work the same I suspect. If it's possible to get a teflon coated bs blade, that alone might solve your problem.
Or else use some bush mechanic solution like building a bath solution of detergent and water inside the base of the bandsaw, with a fixed brush above it, to clean the blade.
ps. I miss the trams in downtown Melbourne.
Expert since 10 am.
Thanks Jackplane,
Trams are great now (Light rail i.e.)especially for those with a Seniors Card.
I have been lubricating blade with a brush dipped in kerosene - works fine but slows things down - I am sure the ceramic guides are the answer.
I am building a model 118 gun ship, and have been collecting Holly which needs to be sawn green.
I am also resawing seasoned Huon pine which is fine.
Thanks for your reply,
Kind regards,
Mountainrider
We run several different Laguna band saws at school and the ceramic guides work well as long as they are properly adjusted and maintained. When we cut resinous wood we have to increase the gap between the guide surfaces and the blade; if we don't the build-up of pitch on the blade can grab and unseat the ceramic elements.
One of our instructors sprays the blade with aerosol cooking spray ("Pam") to help keep pitch from building up on the blade and guides; it's not a perfect preventative, but seems to buy him a little extra time between blade cleanings.
Good luck!
-Jazzdogg-
This is the first I've heard of this. I thought the ceramic guides prevented pitch from accumulating due to the scraping action.
"This is the first I've heard of this. I thought the ceramic guides prevented pitch from accumulating due to the scraping action."
That hasn't been our experience. We normally set the gap between the blade and side-guides at a distance about the thickness of a cigarette paper. However, when we're sawing (particularly re-sawing) resinous species we have to widen the gap considerably; when we've failed to do so, the friction caused by pitch build-up can forcefully pull the ceramics out of their fixtures.
If too much feed pressure is applied, the rear ceramic blade guide ("thrust bearing") and can be scored (or pushed out of position if not secured properly), and the teeth can contact the ceramic side-guides, chewing up the side-guides and taking the set out of the blade. The rear ceramic blade-guide on the Laguna band saws are known to harmlessly throw small sparks in use.
My two cents...-Jazzdogg-
Thanks Jazzdogg,
I was hoping to find that ceramic guides on Laguna would tend to wipe the blade. (Holly Timber I am cutting is still "sappy" rather than resinous).
I presume "Pam" spray is a canola oil or like.Regards,
Mountainrider
In my feeble mind sap is just another kind of resin - it's all hard on saw blades and blade guides.
-Jazzdogg-
To overcome the resin problem companies like Panhans can actually supply you with a blade scraper which goes at the rear of the lower wheel. For resinous or green timbers I've always preferred solid block (hardwood, cast iron or Bakelite/Tufnol) to bearing guides which always seem to clog up or fail prematurely.
Scrit
Re: lubrication, you might want to try the recommended solutions from Suffolk Machinery:
"Pam" spray-on vegetable shortening is a great lubrication for 3/4" WIDTH AND UNDER band saw blades on vertical saws. (EXAMPLE: Delta, Grizzly, Jet, etc.) Unplug the machine. Spray Pam vegetable shortening on a rag and wipe on both sides of the blade while turning the upper wheel by hand. You will hear a 50% sound reduction when cutting.
Thank you Forestgirl,
I will give the chainsaw oil/kero mix a trial. That sounds good.
Moutainrider
