I have a set of bevel edge chisels by Two Cherries and sharpened them with a Veritas Mk.II Honing Guide and Norton water stones. The chisels seemed to be good and sharp with a 1/16″ micro bevel. Here’s my problem. After practicing my half blind dovetails on some spare white ash I had lying around, I noticed that the chisels I was using end up with a small amount of burring on them. Are my chisels any good or did I just not do a good job of sharpening them? The chisels are brand new by the way. Any advice would be appreciated.
If you are positive that the burr formed while you were using the chisels, then the steel in the blades is on the soft side and the edge is curling back on itself as you are driving it into the wood. To be fair, ash is one of the harder woods to chisel through.
You might try increasing the angle of the chisel's bevel by 5 degrees to put a little more steel behind the edge. If the factory bevel was 25 degrees, which is fairly common, the edge would be fragile for working with an especially hard wood, 30 or 35 degrees would be more appropriate. Increasing the angle makes a more robust edge, but the trade off is that the blade requires more pressure to make the cut.
It is possible that the steel in the blades wasn't the correct type or that the blades weren't hardened and tempered properly, in which case they should be returned as defective, but I would try sharpening them to a higher angle first. Presumably you haven't ground them on a power grinder which could ruin the hardness of the steel if done carelessly.
John White
Edited 1/28/2008 8:08 pm ET by JohnWW
