I got about 50 walnut boards that are from 7″ to 13″ at a auction recently. All are rough from 1″ to 1 1/2″ and some are bowed or twisted. I would like to keep them wide and try to hand plane them before I run them through the planner. My jointer is only 6″ wide and common sence says rip them down and use the machine. Or just hand plane just what I would for a top on a bookcase or stand. I learn to hand plane in school in ’58 and am fair at it but I don’t think anyone would ever hire me. So should I get on with my life and rip them down or what would any of you do.
Bill, depending on how warped they are, you will likely need to rip them. Usually with wide boards there is no thickness left after you remove enough wood to make the flat, even if you have a wide jointer. There is much less wood to remove with two narrow boards to make them flat than with one wide one. Lay a staightedge across the ends and check to see.
Woody
Don't get in a rush to smooth the boards. Maximize your yield by cutting the twisted and/or warped planks to slightly oversize dimensions before beginning surfacing. If you need a flat 1 x 12 x 6', no sense planing a 10' board flat, then thicknessing, .. cut it to a rough length first. Do only the 6'-2" long rough plank.
I've seen entire loads of 5/4 and 6/4 by 10', slightly warped and twisted, reduced to 3/4 milled lumber the full 10' ..... only to be cut to lengths of 5' or less, and the owner wishing he had some thicker material!
Good Luck,
John in Texas
I'll second what John said. Don't dimension the lumber until you know what the dimensions are going to end up.
I also agree wholeheartedly with John: wait until you have firm plans for the lumber, then break down the roughsawn lumber into manageable pieces to make tham easier to work with while simultaneously increasing your yield.
Good luck,-Jazzdogg-
Another option for flatting one face of a wide board is to build a sled and use a router with a 1" or so planing bit. Article not too long ago -- was it FWW or one of the other mags? Can't remember.
When you have one flat face, you can plane the other. Another option is to use a sled for your plane and shim the piece level to get one flat face. Then flip over and plane the other side, shims not needed.
Hi Bill,
I'll echo what the others are saying, don't do anything until you know what sizes you need. Also, you can build a sled for the planer to allow you to remove the warp and twist. I saw it in one of Taunton's books on building a workbench. I think the book is simply called The Workbench by Schleining. It is a pretty good read, and has other useful tips about building a bench, including good reasons to buy one.
I vote for wide boards. A simple sled of 3/4 sheet goods and a couple of cross blocks is all you need to use your planer. Shim the board approx level and screw a block to the sled at each end of the board. Screw through the blocks into the end grain of the board. I staple or brad or use double stick tape to attach the shims to the sled and run the whole mess through my planer. Like the others said, rough cut to size 1st then flatten to maximize your yield. If there's too much twist or warp then you have to rip, flatten and edge glue.
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
for me, its a no brainer... hand planes would be the way to go...
Mike Wallace
Stay safe....Have fun
