Hi. I am using a jointer for the first time. The manual said that plywood and MDF should not be used because of safety concerns. Yet I have found more than a few references in books when making jigs, for instance, that say joint the edges of ply or MDF to get flat surfaces. Have you had any problems jointing plywood or MDF? Other than jointing something else and using it to get a straight edge, how have you solved the problem?
Thanks and Happy New Year,
Marty
you'll have two issues here
first of all, never joint the faces of a laminated material like plwood,mdf or particle board, the piece probably will peel apart. edges yes no problem exept that the grain in plywood is half end grain on the edges and wont joint very well
second is the dust especially from mdf, its nasty stuff. if i can, i machine it outside
a decently tuned table saw will cut sheet goods perfectly with a good blade so really a jointer isnt needed any way, i just use an old portable table saw i keep in the shed or my work truck for particle board or mdf and use it outside for that stuff
the other option for those sheet goods is an edge guide system and a circ saw, again a well tuned saw witha decent blade and the edge guide, you'll get a perfect straight cut
and a final note, i dont use mdf for jigs and templates, hate the stuff, that 3/4 paint grade maple plywood from home depot is much better and you can machine it inside
Thanks Steve. I only did the plywood and MDF edges and I noticed the MDF dust right away.
I used MDF for the base of a crosscut sled because it was flat; the pieces of plywood I got from Home Depot were not. I am trying to flatten them with weights. I have also read that Baltic birch plywood is also used often for crosscut jigs and maybe for larger jigs in general. I have not located a supplier of 2x4' or4x4' sheets in my area (near Philly) yet.
Thanks again,
Marty
Most Home Depot and Lowes stores carry Baltic Birch ply in small "handy" panels. Look near their "premium" pine and poplar section.Be sure to check it for flat, however.Another option for jigs is Phenolic ply (1/2" or 3/4") from Woodcraft. Just wait for a free shipping special.Edited 12/28/2008 1:04 pm by RalphBarker
Edited 12/28/2008 1:06 pm by RalphBarker
Previous threads on this forum have indicated that a lot of plywood from the Big Boxes is Chinese junk.
Reported problems include warping, de-laminating and voids. Buyer beware.
Jointing plywood or MDF will just beat up your knives, very quickly. If you can't cut it straight, you should work on that. Either that or get real good at sharpening and changing knives.
Thanks Hammer. I'll joint some solid wood and use that on the saw to get a straight cut for the plywood or MDF. Sound reasonable?
Marty
