Hi,
I am making a wine rack out of melamine particle board. It is going in a kitchen, it is a diamond shaped one that will have one bottle per opening. It will hold roughly 60 bottles. What is the quickest and easiest way to join the dozens of pieces together. I’d been thinking biscuits, but that might be fairly finicky.
Shaun
Biscuits may...I repeat 'may' give you trouble with swelling. You don't say how thick of Melamine, the thicker it is, the less likely biscuits would be to give you trouble with swelling. But I'm guessing 1/2" or less thick is probably what you're planning, so I'd probably not go with biscuits. Dowel's would be a better option or a loose tenon/spline IMHO.
Thanks Jeff, I hadn't even thought of swelling, yikes that could have been quite a mess. Could you clarify for me what a loose tenon/spline IMHO is?
Shaun
Edited 3/7/2007 10:32 am ET by wouldguy
IMHO = "In my humble opinion" A comma would have helped. Here is a link to a commercial loose tenon joinery system, but most people make their own. Here is an article by Tom Hintz about making splines.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thank you all for your help. This gives me some good direction.
Shaun
Sorry, I was short of comma's, when I wrote that, I have more, now...;->)Jeff
"I have more, now...;->)" At that rate, not for long. ROFL!!!!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Shaun
Use fresh biscuits and do not slobber on the glue. They will work just fine for you, but do not glue up a bunch and then leave them as you assembly one element at a time. Glue and insert the biscuit as you go.
There are different size biscuits, so make sure that you use the smaller ones for the smaller work. You should have no problems.
Look into the alternate method suggested to you. Sounds interesting. JL
I'd use shallow dadoes cut with a negative rake dado blade on the TS and apply a solid wood edging once assembled. Much faster and easier repetitive joinery, lots of glue surface, self-aligning on assembly and chipping on the melamine will mostly be concealed in the dado.
Roo Glue
