Hello,
I’m looking to build a desk inspired by the mid-century Danish one in the attached photograph, and am at a loss as to how the top (which I am guessing, from what I know of fine Danish pieces, is solid) is attached to the sides (also solid). It appears to be a hidden bevel/miter joint, but what is most baffling to me is that the top and side grain run in different directions.
So my question is: How did these mid-century makers pull this off without wood movement becoming an issue? All my ideas for a hidden joint (dowels? biscuits? lock miter?) seem as if they would violate the rules of wood movement.
Any advice would be hugely appreciated. Many thanks…
Very often, lumber core plywood is used for the top which eliminates movement issues. You may be able to see the top veneer from the back edge. Various types of furniture grade plywoods have been used in the furniture industry for a long time. They are not the same as the plywood most folks are familiar with.
