Does anyone have informaton aboout the procedures to cut claddagh rings for woodturning ?
What size? Surly not for fingers. I did make a towel ring, and did it (rough out) on a scroll saw and carved the rest.
Bruce S.
The size of the rings is not important. The rings cold be used for pen making, legs for small tables. stems for candlesticks etc. What I,m interested in is what is the besst way to prepare and cut the joinst to make the design? Thanks for the reply. Rich
I'am lost now, sorry.
Explain what you want to do, with a little more detail.Work Safe, Count to 10 when your done for the day !!
Bruce S.
What I am trying to figure out is how to glue up and cut wood to form claddagh rings when they are finnaly turned on a lathe. The end product could be used to make pens, candle sticks, or larger sized legs for tables,etc.
Are we talking about the Claddagh rings with the heart, hands and crown?
I don't know of a way to turn a three dimentional claddagh on a lathe.Work Safe, Count to 10 when your done for the day !!
Bruce S.
Could you not use a dowel, scribe or cut the rough outer size/design, then bore the center out to get the required ID. How close you could come to your final ID might be the challenge.
You would still have to arrive at the final design by other means.Don
Thanks for your reply. I have worked out the sequence to produce the design. It goes like this: Start with a square lenght of stock and cut it in half at a 45 angle. Glue a contrasting thin strip in between each end of the cut. When the glue sets, cut the oppositse 45 angle and glue in another contrasting strip. When the second glue up dries , rotate the glued block 90 egrees and repeat the first two glue ups. When the block dries, turn the block into a cylinder and you will get interlocking rings forming two joined hearts.
Now I know what your talking about. But another twist is to glue up the thin strips on a diagonal, the results look like a celtic knott or a St. Andrews cross. I have done that with pen blanks.
Bruce S.
Edited 3/24/2009 10:42 pm ET by BruceS
Bruce, thanks for the idea about thin strips on a diagonal. I'll give it a try! Rich
Rich, do you have photos?
Ralph, Sorry, no photo's yet, I'm still trying to develop the idea. Rich
