Peter, I’m looking to build new, an irish cupboard. I’d like to finish it just the way the antiques imported from Ireland are. The type of wood I’ll use is contigent on the finish. They have some type of wax finish. Could you help with explaining what it is and how to apply. Thank you.
Clocker 7
clocker7,
Imported antiques, and I've seen a lot of them, are often new pieces made up with old lumber and then waxed. Larger companies actually spray the wax on for production work.
There are many brands of wax to choose from. The two basic types are paste and semi paste. The paste type would include waxes like minwax antigue, bowling alley wax etc. These type contain a high proportion of carnauba wax which is a hard wax. When I use a wax of this type, I'll scoop some into a piece of cheesecloth that is double folded, close it up and rub the surface. This way the application is easily controlled.
The semi paste types are just that; more of a cream like consistency. They will take longer to " build" as they are softer. They come in every color imaginable also.
Another wax recipe is to shave some beeswax into a jar and cover it will mineral spirits until it melts. Warming it up in a hot water bath or leaving it the sun will speed up the process. This is a relatively soft wax and if put on too heavily can be difficult and gummy to remove.
As with any finish , light coats are the norm. Remember, you put some on and then buff it off. It takes a while to build up a wax surface. Be patient. I would also recommend a light sealer coat of shellac before you wax.
A good buffing with a brush, just like the type used in shoe shining , will give it a wonderful glow.
To be sure, I have just scratched the surface. Read some books on the subject. George Franks books talk quite a bit about wax finishes.
Have some fun and let us know how you make out.
Peter Gedrys
