Hi everybody
I need some advise please, I am making a curved door panel from ply. I am veneering the panel and adding some marquetry. My question is how can i add some stringing on the curved panel. I plan on putting the stringing around the marquetry panel. To complicate things I want the stringing in a circle around the marqetry not rectangular. I know how to do it on a flat surface with my router and a cutter the same width as the stringing.
I am attending college at the moment doing a city and guilds in furniture making and this is one of my projects. We are on holiday at the moment so I could do with some advise so I can carry on with it through the hols.
i hope I have wrote it clear enough for somebody to understand
Thanks in advance
Phil.
The simplest solution might be to add the stringing before gluing the veneer to the curved panel. You could cut on the inner circumference using a template and sharp craft knife, tape the stringing to the veneer circle, tape that assembly onto the remainder of the panel, and use it as a template to cut the outer circumference. Tedious, but workable.
Don
Make a curved base for the router? You'd still have to figure out how to guide the thing, but at least that would keep the bit perpendicular to the surface of the door.
Edited 4/3/2004 6:57 pm ET by Uncle Dunc
If you haven't laid the veneer on the panel already, I believe it would be best to make up the veneerface by laminating it to another veneer cross grained. The two ply veneer can be inlaid while it is flat. Set the router's depth to cut thru the show face, but not the underlayment. Inlay the string, and put veneer tape over to hold it til glue dries. Then cover the panel with your inlaid face.
If the panel is already veneered, I'd make up a pattern out of paper, and use it to lay out the circle onto the panel. Trace a single line describing the path of the inlay, with carbon paper. Make up a knife by capturing two blades together in a handle such that their combined thickness equals the width of the stringing. Sharpen the blades by beveling their inside faces, so they will scribe two parallel lines, with parallel outside shoulders. Use the tool to straddle the line laid out from the paper pattern. Start with light pressure (easier to guide accurately), then deepen the cut. Chisel out the waste, and glue in the stringing. Be prepared to work slowly. If you are careful, you will be able to make a good job of it.
Good luck,
