Since aquiring my lathe some time back and thinking I would “add” a little turning to my woodworking repertoire, it has become my new favorite activity (in the shop that is). While I am still a rank novice, and haven’t really turned out much presentable work, I have really made some headway. It can be intimidating (I can still only look at the skew in the tool rack) but it is also an absolute blast. A word to those of you who are time challanged…this is your ticket. I have two small children and a wife who like to see me on occasion, so my time in the shop is very limited. If you are anything like me, I strongly suggest you look into turning. It is really one of the only woodworking branches where you can create beautiful projects start to finish (literally finish) in one session. No glue ups (unless you start doing segmented work) and more free-form flow to your projects. I’m not leaving all of the other stuff behind by any means, but turning really rocks. Does sandpaper count as a turning tool? It seems to be my most used tool.
Joe,
Do you turn bowls or spindles? I don't like turning anything other than green bowls. The wood's easier to cut, produces long strands of shavings with little dust, and, best of all, is usually free. Even better, if you get your bowl blank from the right part of the tree, it will elongate and turn into a truly unique work of art.
Ever use 12-grit sandpaper? We joke that you could turn a bowl with that stuff!
Hey Chris -
I have been trying my hand at both, but bowls really seem to be grabbing me. I haven't tried any green bowls yet, but will soon. There is so much you can do with the design of a bowl, and unlike most other projects (mine especially) a mistake can just take your bowl in another direction.
12 grit sandpaper...is that just a rock, glued to a piece of paper? : )
Joe
12 rocks.
yeah I'm just getting into it, and hope to have a lathe this weekend
The next level is here.... Turning.
Andy,
What lathe are you looking at?Chris @ http://www.flairwoodwork.spaces.live.com
I'm looking at the Central Machinery 45276-3VGA 14"X40" from Harbor Frieght and the 8pc. HSS set by Windsor Design 47066-8VGA also from HF. Both are on sale and I have a coupon for a new store near me.
Andy,
I started out with a lathe similar to that and quickly outgrew it. The four speeds are relatively high for roughing out bowls and there isn't much mass, so you would have to bolt it to a sturdy and heavy stand/bench. As a benchmark, my SC lathe has a slowest speed of 500 RPM (versus Central Machinery's 1125 RPM). I would not want to be spinning an un-true 8" bowl blank much faster than 500 RPM. I think that 1125 RPM would be downright scary.
That said, I think that that lathe would be a good choice for spindle work. It has #2 Morse tapers which are the most common. Check the thread size on the headstock (motorized side). 1" x 8TPI is the most common, but you should be able to find accessories regardless.
I use mine as a doorstop.Chris @ http://www.flairwoodwork.spaces.live.com
I'm mainly going to be doing spindles for now, but that is a good point.
I'll jump in here Andy. I also just got a lathe ( used Jet) which is very similar in appearance to the HF unit. There are a couple of websites which describe how to modify the speed control knob on the Jet to get a slower speed. It looks easy and I will do it sometime soon. I don't know if that's possible with the HF unit, but they do look similar. BTW, for bargain turning stuff, there is a lot offered at Penn State. They have a Wolverine knockoff which I recently bought. It works just fine. davidb
David or anyone,
I just saw this thread. Does anyone have a link to the web site referred to in message #42658.10?
"There are a couple of websites which describe how to modify the speed control knob on the Jet to get a slower speed. It looks easy and I will do it sometime soon. "
Thanks!
John L
Hi John
Here's the one that I saw.
http://home.comcast.net/~hypot/Projects/LatheSpeed.htm
Best wishes,
davidb
Thanks, David!
John,
Before you slow down the speed of your lathe understand that only certain motors can do that. Most motors can burn out if you slow down the speed under the pressure of turning. Look at the thread for further info.
Best,
Jim
Hi JimOn this particular Jet lathe, you are changing the pulley size rather than motor speed. They have a variable diameter pulley system. The extra low speed position just decreases (I think) the pulley diameter a little more. Best wishes,
davidb
Jim,
Thanks for the warning. The Jet 1236 already has the ability to go to a slower speed but there is no detent in that position. The link that David provided just makes it easy to stay at that speed. When I first got the lathe I emailed Jet about what the speeds are and there was one more speed at the lower end that there are detents so I'm sure it's OK.
John
Chris,
Do you have a midi lathe?
Bio
I've got Steel City's variable speed model - 60100.Chris @ http://www.flairwoodwork.spaces.live.com
Andy, I think you will find that the Harbor Freight 34706 is a significantly better lathe than the 45276. It's very similar to the Jet 1236. I've seen the 34706 on sale for $199, which is about what I paid for mine.
That is prety good, BUT It doesn't have a spur drive for turning spindles. and where is it on sale for that low I saw $269?
Edited 7/25/2008 10:28 pm ET by andyfew322
Edited 7/25/2008 10:32 pm ET by andyfew322
It does have a spur center, you can see it in the manual and parts list here. I believe you have to purchase it in one of their stores to get the lower price.
You can't wait for inspiration. You have to go after it with a club. Jack London
OK, I'll see it in the store today, thanks for your help
Andy,I was just in my local Harbor Freight store this morning. The 34706 lathe is on sale for $209.99, "Discount taken at the register".Chuck Taylor
Everett, WA
yeah, I have decided to go with that lathe. I went to the store and immediately turned away from that other one. Once the other lathe is in stock, I will definitely get it.
Be careful with cheap lathes. Where I teach turning we generally recommend a Variable Speed Jet mini, if you are in the market for an inexpensive lathe. The ways on the Harbor Freight lathes are not very ridgid, so when you tighten down on a bowl blank they flex, which is not a good thing. Otherwise I have found the Harbor Freight lathe to be pretty good. As my friend with a HF lathe puts it, "I paid more for my chuck than I did for my lathe, what was I thinking."
You really can turn a 10 inch bowl on a jet mini. And it is a really quiet lathe.
The 10 speed Nova is a good lathe for $1,000, particularly if you can catch it when they throw in a chuck for free.
I am going with a more expensive lathe, though it is from, HF. It is a lot better than the other one I was looking at.
Just a thought. Turning hard wood - wood that is hard can help at first in many ways. You are not constantly schucking up the tail stock to take up play, the finish is easier, you can feel the bevel rubbing and so on.
