How to straighten a TS fence?
In a moment of heightened awareness, I set out to check and align my TS and after I got done with the blade then checked the fence. Normally I start by getting it parallel to the same miter gauge that I check the blade against starting at the near end of the saw and at the back end. Just for grins I simply ran the dial gauge down the miter slot (keeping it pressed tight to the right edge the whole time, and lo and behold there was as much as .008 variation! I then set the gauge at the spot where the leading edge of the blade would be in a typical cut, set my dial to zero and checked several spots. The back of the blade position was about 0.001 farther, not a real problem since I set my blade that way as well (Forrest recommendation) so at the very least it is parallel to the blade. The disturbing part was that in the foot or so in front of the blade the fence curved toward the blade about 0.007!!! It then curved away as it got closer to the leading edge of the table.
I am assuming my miter slot is straight (I have no really reliable way of checking it, I don’t trust my straightedges that much) and it actually explains some of the weirdness I have gotten in rips lately.
The fence is a Jet Exacta, so the faces are HDPE polyethylene. I checked that the screws holding it on were snug.
If the face was wood, heck I’d just run it through the jointer – but its not. Any idea how to get it to true? Is a replacement from Jet in order, and if so it is likely to be more true? Anyone run into this, I’d appreciate hearing about your experiences.
Roger
Roger
I’d rather be making cabinets and friends….
roger,
fellow californian!
is it possible to loosen the material which serves as your fence and insinuate some shim stock behind it?
also, are you saying that your miter slots were milled such that they are not parallel with each other? that sounds serious. what kind of a saw is it?
eef
i have an old grizzly g1023 and am able to square the fence by way of two set screws. i believe that most fences are made so that one may change the surfaces on which the wood rides.
eef
Edited 9/24/2009 4:27 pm ET by Eef
Its good to work in a warm shop nearly year round here, isn't it?No, the miter slots are parallel, I just was not able to verify that they are in fact true and straight so I will assume so. Actually, I did check with the best straightedge I had and it confirms what the measurements with the dial indicator told me - compared to the miter slot, the fence is bowed in at the middle by about .005 (slipping a leaf gauge between the straightedge and the fence vs not being able to slip the smallest leaf I had between the straightedge and the miter slot edge).The face is pretty thick so I doubt that shimming it will work, but I have nothing to lose at this point. I am also wondering if the material is soft enough to put through the jointer, just take a hair off.... I doubt I could get it smooth enough though.I just checked and a replacement left face is nearly $100. If I thought it would be true I'd spring for it. Maybe I will call WMH Tool before ordering.RogerRogerI'd rather be making cabinets and friends....
roger,mike hates the plastic crap-from experience. i find that i need to replace the "after-market" fence from time to time. i like mike's advice to you.eef
First, before you try anything else: Remove the plastic face, and confirm that the body of the fence is true. The plastic is pretty strong in compression, and smooth, with a low coefficient of friction. (Which is why they used it for the fence face.) But, it is not rigid. So, if the body of the fence is warped, it will follow the warp. And, if you put on a MDF face, it too will conform to the warp in the fence, solving nothing.
Edited 9/24/2009 10:46 pm ET by Jigs-n-fixtures
You are correct in what say about verifying the steel tube fence is straight to begin with. The steel would have to be machined and the plastic crap straight as well. With my fence the steel appears to be machined. I borrowed my cousins straight edge, and found that the fence was perfect to the naked eye. With the plastic crap on the was a bulge at the front and a hollow at the blade. I used feeler gauges as I did not have an indicator at the time. The bulge was about .035 the hollow was worse.
I removed the fence, with the plastic crap intact. Took it to my cousins machine shop. After some inspection and checking ,Tom told me to return the plastic crap because he wasn't going to try and surface grind the plastic crap.
Tom said to me, why don't you use plywood like his dad had on a unisaw. I forgot that the beismier used plywood. I had mdo scraps left from porch columns that I wrapped. Put the mdo on and that took care of it.By the way, mdo is not mdf.Mdo is medium density overlay. The difference is the core is plywood and the face is a water resistant face.Mdf is medium density fiberboard, also goes in the crap catagory.
mike
Remove the plastic crap and replace it with a piece of 1/2" mdo ( medium density overlay.After installing the mdo, check it with a good straightedge.If the steel tube rail was machined straight the mdo will be straight. If not,tape thin shims or just layers of masking tape in the concave areas.
I have a piece of the plastic crap that I removed from the fence.It is not straight and I am not going to try and joint or sand this stuff. Come to think of it I have two pieces of this crap.
mike
LOL - Mike, c'mon - tell us how you REALLY feel!This sounds like good advice and certainly easy to try, and a LOT cheaper than the $100 it would cost to get the mfg replacement part. Thanks!
BW, my Powermatic fence has the same problem. For the longest time I kept blaming anything from bad technique to the blade coming out of alignment. I spent hours realigning my trunnion and finally discovered, like you, that it was a bow in the fence. As others said, take the faces off and confirm the metal body of the fence is straight. (I bet it is). My UHMW plastic faces bow and shimming the low spots is a pain. I've been thinking about making replacement faces and that might be your best bet.
Have you put a straight edge across the whole length of the fence?
HDPE polyethylene bends under compression -- a lot.
It may be that your bolts are too tight rather than loose as you first checked for.
If it is that problem, think about replacing it with a different flat material like MDF faced with a thin film of HDPE polyethylene and reset your cursor.
I have that fence, and found the same problem. The plastic is too floppy, and the attachment things distort it. I replaced it with wood. Wood is more rigid, and you can do things like plane it. You can also put shims between it and the steel if your steel isn't quite as straight as you like. Amen to the prior poster's opinion of plastic faces!
