Hi,
Help!!!
I’m currently building a cherry Shaker hall table for a Church auction.
I’m almost done with the construction of the table, but noticed that several pieces are lighter than the others.
I know that as cherry ages it will all darken and match, BUT I don’t have time…the auction is 3 weeks away!!
I think I read about a solution that will age cherry quickly. Does anyone know anything about this???? Or had any experience with this??? Or any other suggestions???
I really don’t want to use a stain or dye…
(FYI I will be finishing the piece with a homemade wipe-on finish made with 1/3 poly, 1/3 turpentine and 1/3 boiled linseed oil which I find works great on cherry)
Thanks for your help!!!
JJ,
Since you don't want to use a stain, your only alternative is to "suntan" the pieces, IMHO. Length of time determines the darkness. Good Luck.
Dano
*there are a number of ways to darken cherry. My favorite is easy, reliable and cheap. Take a spackle pail half full of hardwood ash from your wood stove or fireplace, pour a large pot of boiling water over this. Allow a day or two to settle-out and ladel off the alkaline brine that results. This solution brushed on the cherry before finishing will immedeately darken the cherry. It reacts with the tanins. It does raise the grain some, so finish sanding will need to follow. I have used it countless times under a watco finish. I never bothered to neutralize the surface though I probably should of. This will not darken sapwood.
*There is a really easy really fast way to age Cherry. Mix 1 tablespoon of standard household lye ( Red Devil is good ) with 1 cup of warm water. Brush it on and watch the wood change color. It is beautiful. After a few minutes wipe off the excess and let dry overnight. It will raise the grain but you can knock that back down with some 400 I/I paper.
