We have rain forecast for the next few days, and the shop will definitely see an increase in humidity. I have been reading lately that it is better to wait out the storm and cut wood when the humidity returns to “normal”.
More importantly, I am going to be making 3 desks and 2 tables, all with tapered legs cut from 10/4 and 12/4 stock. Is it better to face joint and plane this stock as a wide board, then rip to width, or would it be better to rip to a rough width on the bandsaw, let those pieces acclimate, and then joint/plane each leg individually? Any thoughts on doing this ahead of the storm?
I would rip your leg blanks to rough size with the bandsaw first.
I've never noticed any difference cutting material on rainy or dry days. I live on the Southern Oregon coast where we get moderate humidity. But if you live on the East coast or in the South maybe it's a different matter. I've been working wood for 30+ years and never heard of this being a problem.
Paul
Cut to rough size first, allow to acclimate, then joint and plane. There will inevitably some unpredictable movement of the material after the rough cuts are made, so you don't want to joint and plane until you've let that movement happen.
Assuming you're not expecting a deluge of Biblical proportions, whether you make the rough cuts before, during or after the storm doesn't matter much, as long as you allow the wood to acclimate for a few days in "normal" humidity conditions. So, if you cut today, and it rains for the next couple of days, wait an additional three or four days (a week would be better) after the rain ends.
I have a humitity meter in my shop with temp. I always check when I walk in just to get an idea of whats happening. Not what the number is, but is it changing a lot. When I cut my pieces from the main rough stock, I sticker and set aside for 1 - 2 weeks (if possible) to let aclimate. I've never had an issue.
