I have a 98 percent full quart of shellac. Date on the can says it was manufactured in 2002. I have put some on a piece of wood, and the first coat appears to have dried completely. Sanded it and just applied a 2nd coat.
I know shelf-life is supposed to be “not long.” Bulls Eye (this brand) says theirs is 3 years.
Anyone know any technical information? Anyone know any practical information?
Should I use it as long as it appears to be drying properly?
Alan – planesaw
"How old shellac?"
Old shellac fine. How you?
Ba dum, bum.
If it dries rapidly and is hard enough to scuff sand to a fine, dry powder in 24-48 hours, it is behaving normally. Use it.
Rich
Good one.
I think you and Steve have given me the practical info I need.
Alan - planesaw
Alan, please report back when your complete test results are in. I've pushed the envelope on the Bullseye by close to a year, but you're well past that. It'll be interesting to know how things go.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Well, I am in my office now with my keyboard sitting on the piece of Baltic birch that has two coats of the shellac-in-question on it. Everything seems fine.
However -- the point made earlier about a new piece of wood versus a nonporous surface may (along with the fact that the can was 98 percent full, i.e., little oxygen) explain my "success." I probably won't push this, and I certainly wouldn't use it on anything I had a lot of time and energy in.
The amber color seems deeper, but that may be my imagination.
Alan - planesaw
The "esterfication" that causes shellac to go bad isn't an oxygen curing process like what happens to varnish that gels or skins over in the can. Cool strorage conditions extends life, as does higher cuts versus lower cuts.
Use if if it dries properly. But your best test would be to apply a coat or two to an non-porous surface. It can be hard to tell about the first coat or two that mostly sinks into the wood.
I believe that Bullseye shellac includes some chemistry that extends shelf life. Pure shellac flakes dissolved in ethanol do not have a 3 year shelf life. But Bullseye does keep a long time ... from experience.
