Has anyone had success honing a radiused blade?
reepenstien,
no problems - but it needs to be done freehand.
How good are you at freehand sharpening?
eddie
Fair to middlen, but I still hone anything above 4000 grit, with a jig. Any suggestions?
Hi again,
Here's a link to a summary of how I sharpen freehand from a previous post.
http://forums.taunton.com/tp-knots/messages?msg=13980.5
Also another discussion on this same topic:
http://forums.taunton.com/tp-knots/messages?msg=11364.1
Cheers (work started 30sec ago)
eddie.
Thanks, I'll take a gander and go from there.
reepenstien,
I do it regularly, and I use a jig. Actually I use one of three jigs; they all do the job.
All I do is to press down on one corner, and nowhere else, and then press down on the other corner, move a finger's width towards the center of the iron, press there...ad nauseam.
The only iron I haven't been able to sharpen this way is the one in my ECE scrub plane. The arc is simply too great. That iron I have to do freehand.
Alan
Not too long ago I posted the same question because I needed to hone my ECE scrub plan, like Alan. I was pleasantly surprised to fine that I could do it quite well by hand. Try it.
Alan, Mark, thanks..I'll give it a shoot this weekend. My only concern is that a scrub plane doesn't need to be particularly sharp...therefore the comparison is suspect.
The motion is no different; simply progress to ever finer grits of whatever you use - stones, sandpaper, etc.......
FWIW, a really sharp scrub plane iron is certainly not an outright hinderance to the job it does for you. It is true, however, that you can spend a little less time on it and get good performance. But I would not take this notion to a ridiculous extreme.
I suppose a scrub plane doesn't NEED to be as sharp as say, a #4, but I can assure you that when I was finished honing the iron it WAS as sharp. In fact, it was probably a little sharper because I spent more time with it to make sure.
Ok, good counterpoints. I'll hide out in the shop this weekend and see what I can do, thanks to all for the responses. Feel free to add any new thoughts.
Once you learn to do these freehand, and you really should, you'll want to do all your honing freehand. Save the jig for those times when you need to re-grind a primary bevel.
