I am preparing to build a pair of demilune tables out of mahogany and wish to add a small amount of banding out of a white wood, possibly holly. Since I wish to keep the finish natural, I am not sure how to avoid darkening the inlay. I assume the best way is to install the inly after finishing the mahogany. However, how can I get the inlay surface smooth and flush without damaging the mahogany. Also, what glue is best?
Not having done this before I am looking for some experienced guidance.
Thanks…Bill
Bill,
There are two ways to color inlaid pieces. One is to use a chemical that will alter the mahogany but not the inlays and the other is to seal the inlays and then color the wood. I have done it both ways, but now I use a combination of both on most pieces. I color the wood with the chemical and then seal the inlays and further enhance the altered wood with dyed oil.
I have used a third way that involves putting the piece in the sun, but that will only work in limited circumstances, due to the sun not falling evenly on the piece, and the potential for disastrous warping. I used the sun to color the screen portion of a firescreen and the results were pleasing, but there was no chance of it warping.
Of course there is a fourth way, which is to let time do the job for you, but it will take quite a while with today's much lighter mahogany.
The following to links give an overview of the finishing process of inlaid pieces.
http://americanfederalperiod.com/Tea%201.html
http://americanfederalperiod.com/T%20desk%201.html
Rob Millard
