I have a nice piece of redwood burl with a great live edge. It has been coated with anchor seal. Does anybody have a good way to take off this waxy emulsion sealer without scratching up the wood (wire brush)? Thanks, Chris
Use a properly sharpened cabinet scraper to remove the wax. The sealer will possibly have penetrated deeply into the end grain, which is quite porous, so you may problems removing all of it unless you plane or sand off quite a bit of wood.
John White
Thanks John, I guess my wood vocabulary needs improvement. I'm talking about the outer growth of the burl. I'm posting a couple of pictures to clarify. Thanks, Chris
Naphtha will probably remove the bulk of it, but there will undoubtedly be some left behind. I think the truth is that Anchor Seal really shouldn't be used on what is expected to be a final finished surface.
As the other poster suggested, a solvent like naphtha, which would be my first choice, worked in with a stiff brush, if needed, and wiped up with towels. No matter what you do some wax will be left behind so you shouldn't plan on a water based finish for the piece.John W.
Tinter
mohawk sells a product called wax-off which may reqiure acouple aplacations but will re move all the wax
Dan the woodbug
Thanks Dan, I'll give them a shout. I used a heat gun to melt it and it worked fairly well, but there is still sealer on the wood. Thanks again for the tip. Chris
they also sell special straw brushs meant for cleaning out grains while stipping furniture /I beleive the ones you would need are mock &mick or hard and medium bristle .your welcome anytime hope all goes well
the woodbug Dan
I bougjt a piece of maple and it came like that. I called Anchor Seal. They suggested waterblasting it off with warm water. Not having the setup, I took it off with a hand plane. No problem. They were quite helpfull. Give them a call.
Thanks for the advice Hal, I have a couple of options, but a call to Anchor seal would probably be beneficial before I get too involved. Thanks again, Chris
