I am going to be building a 5′ tall doll cabinet of mahogany frames with glass panels. There will be one door in the center front with a front panel on either side of it. The side panels will be glass in frames as well. The back panel will be hardwood frames with 1/4″ mahogany ply for the panels. All the frame stiles/rails will be 2″ wide.
Is there a preferred method for attaching the side and front panels (and side and back panels as well) together? I realize there’s probably not one right answer, and I’ve seen arguments for and against T&G, dowels, biscuits, rabbets, pocket holes, etc. I’ve used biscuits for built-ins, bookcases, and other cabinets but never on fine furniture.
If this is to be considered an heirloom project (as I would like it to be), is there a “best” way? Is there a traditional way?
Thanks, and I appreciate all the feedback I can get.
Fine Woodworking Recommended Products
French Curves
An essential for drawing and designing with curves.
Porter-Cable 382 5-in. Random Orbit Sander
- Without a vacuum, toward the bottom of the pack in stock removal and dust collection - With a vacuum, stock removal was good and dust collection was excellent - Slowest to stop - Not much to grip when held on top.
Rockler Deluxe Panel Clamp
These clamps can handle glue-ups between 10 in. and 36 in. wide, and boards up to 3 in. thick. Sliding feet attach to the lower bars with magnets, letting you position them quickly for stability on any surface. The spring-loaded jaws adjust easily, dropping into notches along the bars. And the powerful clamp handles clear the benchtop.
Festool TSC 55 KEB Track Saw
This saw is nearly identical to the TSC 55 REB, with two main upgrades. The first is a thinner blade that cuts quicker and extends battery life up to 40%, according to Festool. The second is the headline-grabber: an anti-kickback device that replaces the riving knife. The KEB is compatible with older Festool tracks and batteries. You can buy just the bare tool, the tool with the batteries, or the tool with the batteries and a 55-in. track.
Triton TPT125 Planer
Accessing the knives on the Triton for changes was not difficult, but getting the knives out was tricky, because no magnetized handles were provided to lift the knives off the cutterhead. There is a 2-1/2-in.-dia. dust port, and chip collection was good when hooked up to a shop vacuum. The housing has an open top and just one return roller on top, making it impossible to stack boards there in between passes through the machine. Also, there is no gauge that indicates how much material you are removing in a pass, making it one of four planers that don’t offer this feature.
gremlin,
I built a similar piece a few years back. I simply butted and glued the front stiles to the sides, after the front and side frames were assembled. It's a long grain glue surface, no need for dowels, pins, pocket screws, or biscuits, in my opinion. Unless you feel a need for help in alignment during glue up.
Consider making the side frame's stiles that abut the front frame narrower than the others, to allow for the thickness of the front frame. In other words, if your stiles are 2", and the stock is 7/8"thick, the two stiles that get glued to the front frame should be 1 1/8" wide, to make 2" when glued to the 7/8"thick front. If you can match the grain across the joint, it'll be inconspicuous.
I rabbeted the rear stiles of the side frames, to accept the back, after assembly. I finished the cabinet, installed the glass, then put the back frame in place. I used screws to attach it, to make acess for replacement of any broken glass easier.
Any joinery that gets the job done, is strong and looks good, is good. That’s how Tage Frid would have looked at it. Also, if tradition is an issue, lose the plywood back.
Fair point. I had actually considered using hardwood panels instead of plywood, and may still reconsider.
I built a repro of a china press a few years ago using mitered joints for the styles on the front corners. Both pieces,front and side,are made from the same piece of stock,and are both the same width. The stock must be straight,of even thickness,and all edges parallel.I use the bandsaw set up to make the rip cut down the center of the strip. This takes less out of the grain pattern and is easier for me to do.The sawed edges can now be beveled to 45 degrees by whatever method you are most comfortable with.
I use the tape method to assemble the 2 parts for glue up. When carefully done,the grain pattern will be contineous around the front post.With careful stock selection,the grain pattern on the 2 front posts can be made to be opposite each other.
Thank you,Mr.Croney,where ever you may be.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
Edited 10/14/2004 12:28 pm ET by Pat
