I’m not new to woodworking, but my projects for the last few years have been wooden boxes and scale wooden model ships. I’ve got a pretty full featured shop and I have need of a blanket chest for storage so I thought I’d try my hand at furniture. I’ve looked around quite a bit but can’t find any designs that particularly appeal to me so I think I’ll design my own. I intend to use frame and panel construction with plywood/veneered panel sections for the sides. Rather than cut my teeth on dovetails for the corners I think I’ll use a sliding dovetail at each one. The top will be a glue up of 3 pieces of solid walnut with biscuit joinery. And that brings me to my question about hardware.
I haven’t had to worry about expansion/contraction with the small projects I’ve done but I’m well aware that I must take that into consideration with a roughly 25x42x3/4 lid. I’d like to use antique strap hinges but it occurs to me that if I screw them into place I am securing the wood to a particular width at the same time if the hinge crosses a joint. Will this invite cracking over time? If so, what’s the work around?
And secondly, somewhere I could swear I saw a hinge used on a project in some magazine fairly recently that would hold it’s position so the lid wouldn’t slam. Does anyone know what hinge I might be thinking of? Or barring that, what sort of hardware could I use that would keep the lid from slamming on little (and bigger) fingers?
Thanks so much,
Ken
Edited 7/18/2009 7:43 pm ET by SparrowHawk
Ken,
To allow movement in a 25" wide lid, you could either use undersized pan head screws/oversized holes in the hardware for expansion, anticipate or build the lid with small gaps (if the style permits) or use quartersawn lumber.
To keep the lid from slamming, I don't know of any hinges that do such a thing. What you want is a lid stay. They keep the lid open (and from opening too far). Some hold the lid up as well and require you to close the lid yourself.
and www.flairwoodwork.spaces.live.com)
Thanks Chris .. yeah, a lid stay. Makes sense .. a well trained lid .. STAY! :)How much movement do you think I should allow for say an 8" wide x 3/4 thick piece of black walnut in Florida but always in A/C?Thanks Ken
Ken,I don't know Florida's climate well (humid?) or how well your AC regulates humidity, but I would take a meaningless guess and say 1/16" or more?Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
"And secondly, somewhere I could swear I saw a hinge used on a project in some magazine fairly recently that would hold it's position so the lid wouldn't slam. Does anyone know what hinge I might be thinking of? Or barring that, what sort of hardware could I use that would keep the lid from slamming on little (and bigger) fingers?"
Actually, there are such things as chest hinges that incorporate a built-in stay. Rockler sells some, though these are not the traditional type of strap hinges:
http://www.rockler.com/product.cfm?page=21288&filter=chest%20hinges
Personally, I prefer a separate lid-stay, and I really like the version that Lee Valley sells. Because it's hydraulic and not based on a friction-plate system, it's unlikely that wear will make it ineffective over time:
http://www.leevalley.com/hardware/page.aspx?c=2&p=40596&cat=3,41427,41390
Regarding strap hinges, you're correct that screws could potentially cause the lid to crack, but generally speaking one uses so-called "pyramid screws" with traditional strap hinges, and these screws have a flat bottom on the head, and will allow the wooden lid to move up to the limit of the holes in the hinge.
Thank you .. that makes sense. I like the look of the strap hinges so a lid stay would be the way to go. I agree that hydraulic is better than friction - I'll definitely be using one of those and it's safer for fingers. It seems to me that it would be somewhat better to try to find a strap hinge that only attaches to one panel in the lid if possible as I would think that would minimize the risk from any variations in the amount of movement from one plank to another. Thanks again!
Ken
