I’m going to build a hot tub and have never done any coopering before. I plan to make the tub about 60″ in diameter. Are there rules, or does anyone have suggestions, about how many sections I should make? I’d just as soon do as few as possible, especially since this is my first coopering project. Thanks!
yup..there are 'canoe' router bits. a hollow and round set. using these you can make water tite joints very easily, and the radius or finish diameter does not have to be a 'dead on' mathmatical process. Redwood staves are what ya want, and steel hoops.
the bottom is the challenge. A cooper would have a croze (sp?) a circular router plane for grooving the barrel for the head. In your case a piloted 3 wing slot cutter ought to suffice, maybe needing 2 passes..I would make the groove no less than 1/2" by 1/3 rd the thickness of the staves..the bottom needs to float (no pun) like a raised panel..being as it must swell to attain watertiteness.
As a rule, build it loose..it has to swell and not explode.
Spheramid Enterprises Architectural Woodworks
Repairs, Remodeling, Restorations.
If I understand you, Sphere, the "canoe" router bits would yield a joint similar to a tongue-and-groove?
I had actually thought to build the tub with coopering techniques but clad the interior with fibreglass (old boatbuilder here). That way I get the aesthetics of the wooden tub but the watertightness of the 'glass. I don't really give a rodent's rear what it looks like inside as long as it holds the water...
The canoe bits cut a Bullnose (male ) and a mating half circle(female) The angle isnt crucial because the joint can rotate a little, like a ball and socket.
