I have a pair of backsaws, both cheapo Stanley 14″ “Miter box saws. Getting tired of the PLASTIC handles, blister making things. So, went out to the shop ( Hey, it got up into the 50s!) and got a bit of old oak ready. I laid out one handle as is, and a second handle a little different. I then cut both out, and shaped them a bit. Round-over bit, 4-in-1 rasps, regular rasps, a belt from a beltsander. Drilled out for two sawnuts, and installed them. The sawnuts came from a “Toolbox” handsaw. I used that saw to cut a kerf for the blade to slide into. I also got out a small chisel and chopped a slot for the blade’s back to slide into. Still needs a lot of sanding, and some sort of finish.
One saw “re-habbed” at least one more to go.. Photo #1 shows the before, #2 shows a blank being cut out, #3 shows the blank installed. Still needs to be finished up.
More photos
Just a few more photos of these saws, yes, I said saws. Two were re-habbed. Shaped, sanded and stained. Three bolt saw is a 14" backsaw, the two bolt one is a 12" backsaw. Never be L-Ns, but these will do in my shop.
