Yes I’m trying to join the ranks of the handtool savy. I’m embarking on the slippery path of custom hand tooled joinery… etc. Does anyone know of a good article on basic handcut dovetails. One that describes in detail how to setup, measure and layout the pins and tails. I’ve found a lot of articles and books that talk extensively about the cutting, yet, none start with the basic measurements and layout. If anyone has a good article in their computer, and can somehow post it that would be great otherwise good old fashion advise will be appreciated, thanks.
Frank Klaus has a video out on making drawers using hand cut dove tails. I have seen him do it in person and he is a guy to watch.
Wicked Decent Woodworks
Rochester NH
" If the women dont find you handsome, they should at least find you handy........yessa!"
I have to second that recommendation. I just got the video back from a friend who had kept it for about five years. I learn something every time I watch it. I also have a video of Tage Frid cutting dovetails. It is intersting that these two masters go about it in pretty different ways.
Dick Durbin
Mikemd,
Without a doubt Ian Kirby's paperback 'The Complete Dovetail' covers all the aspects your looking for......process as well as technique...and includes a philosophy.
I also like Phil Lowe's approach especially relative to body position and execution. Their was a video clip on here showing him cutting dovetails last year. It may not be available but you can check.
basic handcut dovetails................
I do that... Router looks better but I'm not sure REALLY how they should look when fisst made.. I see OLD and New hand cut and thinks the REAL old ones were NOT perfect.. Am I wrong???
Fit that is... I see dovetails on old stuff that look OK but joints filled with dust?
Edited 3/4/2005 6:05 pm ET by Will George
Drawer dovetails in period furniture, were often looked at as a means to an end and could be quite crude, even on excellent furniture. Looking at drawer dovetails, and exposed dovetails, such as those on blanket chests or drawer dividers, the latter will almost always be of better quality. This tells me, that the original maker spent time where necessary, and put on the speed elsewhere. Many masterpieces of old furniture are just hacked together. Also, earlier furniture will typically show less refined dovetails. For example comparing two pieces of equal overall quality from the William and Mary and the federal period, the federal will usually have dovetails of better quality. The cabinetmakers then ( and some today) worked under a lot of pressure and poor conditions ( try cutting dovetails by candle light). There are of course exceptions to this, with the dovetails by the Goddard-Townsend, Seymour and son, and Lannuier, to name a few. These makers took great care with the dovetails, especially Lannuier. The major shortcoming I see with period dovetails as compared to top quality ones, is saw cut over runs, and irregular spacing ( done by eye), both evidence of emphasis on speed and not any lack of skill.
Right now, I'm making a Chippendale Philadelphia chest on frame, and I had to actually work harder to make the less than perfect dovetails typical of these pieces, as compared to the federal period dovetails I most often cut.
Rob Millard
There's a website you should take a look at... it really helped me.
http://www2.gol.com/users/nhavens/htmlfile/dt1-e.html
Good luck!
I got the Frank Klaus video when I first started woodworking and was fairly "green". It was easy to follow and I produced perfect dovetails on the first try. It saved me from trying to interpret the pictures of a printed article.
Good luck.
Edited 3/4/2005 8:45 pm ET by workinhard
I have to agree with CherryJohn...Frank Klause. I too have seen him in person and actually have an autographed sample dovetail joint he cut at a show I went to in Portland Maine. His system using very little measuring which is nice. About all he uses is a marking guage. No sliding bevels, rulers, dovetail gauges. I'm a weekend warrier and the system has worked really well for me even though I only cut them a few times a year.
A skill well worth learning...Good luck!
Lonnie Bird did the cover story for Popular Woodworking in the Feb. '05 issue - "Your First Hand-Cut Dovetails." The next issue, coming out in mid-late March, includes another article by him entitled "Fundamentals of Layout."
I'd been getting closer and closer to good-quality dovetails before I read Bird's article. But once I read it, I just got it. Maybe I was ready for it and it could have been anybody, but I think there was a simplicity to his approach that helped me out a lot.
I would get the Feb. issue of PW, and follow up with the April issue (mid-March) which includes the article focusing on layout. You may be pleasantly surprised...
Good luck,
Mitch
"I'm always humbled by how much I DON'T know..."
Good for you. The best advice that I can give is to tell you to buy Rob Cosmans video, basic dovetails available at Lie-Nielsen website. Rob shows you how to accurately lay them out using the Alan Peters method and how to achieve perfect results even on your first try. Well worth the money. Peter
Here is my most recent set. I learned from Rob Cosman. Buy the video.
Peter,
That's a beautiful piece (your devotion to Rob Cosman notwithstanding...:-)).
But I was struck by the thinness of the inner pins. I imagine that structurally they're not as important as the outer pins, which are thicker and therfore stronger. But my smallest chisel is 4mm, and that wouldn't begin to fit into the almost non-existent small end of the interior pins. Do you use a small-kerf Japanese/Dozuki saw to more or less "disintegrate" the waste?
Let me know,
Mitch
Hi Mitch. Thanks for the kind words[notwithstanding :) ] When I first learned to cut dovetails we were shown that the joint will always be stronger than the application it is required in. I have taken 2 pieces of hardwood 3/4" thick by 3" wide by 6" long, dovetailed them together with very narrow pins and then set the triangle on the floor and stood on the corner. I weigh 210 and it did not break. The point of all this is that esthetics come first in dovetailing. The pins are not all that thin in this example, I will sometimes cut them about 1/2 as thin. When I cut my tails [first] all I do is just saw to the line. This way you can have a pin width of just your saw kerf. I use a Independence saw. If you have a decent saw you can saw to the line and not require any chisel work on the sides, and make your pins as narrow as you like. Talk to you later. Peter Buy the video:)
Mike, Here's an attached image of a method for marking out for the front lap dovetails and back through dovetails of a typical drawer side. The rule is used diagonally across the part to find a convenient number to divide by, e.g., if you want two full pins with the normal 1/2 pin at either end then hold the rule at a diagonal to find something easily divisible by three, e.g., 90 mm, 6", etc.. Slainte.
Sgian,
That picture makes it clear how to layout the half laped dovetails in the drawer front, nice trick, but I'm a bit confused with the back side through dovetails. Where do you lay the rule ? If I'm pivoting my rule to create three tails...where do I start? thanks
Opps ! I think I got it now....start for the top of the back board (ie. board joining the side board) and pivot to the top of the floor dado
Edited 3/5/2005 11:31 am ET by BG
Mike,
A few things I forgot to mention about layout tools:
I hope this lengthy message is of help and gives some asurance that hand-cutting dovetails doesn't have to be an exercise in geometry and advanced mathematics - it can be very intuitive, and should be enjoyable.
Best regards,
Mitch
To expand on what has been said before, don't get too hung up on the details of 'how' to cut dovetails, concern yourself with "do they look good?". If there are problems in execution, practice on scrap wood. Any hand work is going to depend on muscle memory and the more times the operation is done correctly, the better the results will be. Symmetry isn't absolutely necessary. The best examples of fine furniture look good, but from a technical standpoint, they aren't perfect. They weren't trying to be perfect when they made these. There's no reason to measure anything with a ruler when cutting dovetails, but a marking gauge, knowing how to use dividers and developing a trained eye make will yield the results desired.For those who aren't too familiar with dividing spans and shapes without a ruler or scale, get a drafting book. An angle or line can be bisected or trisected very easily with a compass. If you want even spacing along a line and have a ruler, you don't need to do any math to divide it into almost any number of pieces. This is like anything else, it takes practice to get the results. If someone doesn't have the money to buy all of the best tools (like the old craftsmen), become fluent with what is available.
"whcih should come first? - I've had great success with cutting the pins first, but....."
Each to their own of course Mike, but for speed I cut the tails first, on the basis that time is money and I try to maximise profits and keep down client charges wherever and whenever I can. It's always quicker especially if you have several parts all the same to do. If four drawers are all the same height, stack eight sides together and saw the rakes front and back in just two operations instead of sixteen. Even a single drawer normally has two sides the same so these can be put together as a two pack and all front and rear tail rakes cut in just two operations instead of four.
If pins are cut first each has to be cut individually, transfered individually, and the matching tails cut individually. I prefer to save this order of operation for where it must be done in this order, i.e., when executing such versions as the secret lapped, secret double lapped, and the secret mitred dovetail.
I must admit that nowadays I seldom carefully fully mark out my dovetails-- I tend to just eyeball the darned things. And just for fun I sometimes demonstrate the five minute rear drawer dovetail and the ten minute front lap dovetail just to keep the learners on their toes, ha, ha. Slainte.RJFurniture
