For those of you who utilize hand planes in working wood, I am wondering what wood you most often choose for it’s planability?
I find that they are all planable, just a matter of bed angle (the angle at which the plane iron attacks the wood.) Softwoods want a lower angle, say 30-35 deg; figured hardwoods want a steeper angle, like 50 deg, and others fall in to an average range of around 45 deg. They all want to see a very sharp iron.
Charlie
Thanks Charlie
I'm considering making a child's play table for my Grandsons out of Ash. What is your view on it's planability?
It's planable. Your tools need to be well tuned and sharp, though, and properly set up. I'm still working on that part. This is vastly easier with a Bedrock style of plane, lemmee tell ya.CharlieI tell you, we are here to fart around, and don't let anybody tell you different. --K Vonnegut
Walnut is my favorite wood to hand plane. With a sharp plane, it cuts easily, seems like there's no wrong direction, the shavings are nice and fluffy, and it even sounds nice.
and Walnut is so relaxingly fragrant when planed or sawn.
My standard daily workout is 5 minutes of the hardest wood I can find, using the smallest plane I can find.
I attach this morning's picture.
Larry,
Ash despite its hardness is quite easy to plane.
I like to plane mahogany, walnut, cherry, clear white pine ( not surprisingly this is the best), and with the proper plane curly soft maple. Holly and ebony aren't too bad either. I dislike planing satinwood, purple heart, the lighter colored poplar, and hard maple. Birch can sometimes be a pain, sometimes a joy. The very few times I've used it, red oak seems okay and white oak is nice, but I've not worked with quarter sawn.
Rob Millard
All the replies above are on point. Almost any hardwood will plane nicely if the plane is high quality and the blade is very sharp. Personally, I find cherry the most consistently easy wood to work by hand.
Larry,
Six things are necessary to plane effectively: the ability to read the grain of the wood being planed, and the ability to tune up (fettle) your plane for optimum performance,practice, practice, practice and practice.
Good luck,
-Jazzdogg-
I have to admit.. ease of use has never been a consideration when selecting material.. With the planes I have, it's a sure bet that they can handle anything I set them to... whether I can is usually a different matter however.. ;)
The easiest wood I've worked has to be Indian Rosewood; all that oil in the wood made it self lubricating... effortless to work...
Most satisfying to work was sycamore... delicate grain, real soft.. but fragile too.. had a tendancy to tear out right when you thought you had it just about done.. It tought me how to get the most from my #62..
Oak tends to be pretty reliable stuff to work; it's hard on blades, but once you're working with the grain all it takes is patience... seldom any hidden surprises..
Mike Wallace
Stay safe....Have fun
