I’m “new” here so I’m asking if anyone had built Greene And Greene floor lamps and lampshades? I’m sure the base and post shouldn’t be any difficult but I’m kinda lost on the shade angle cutting plans..
Fine Woodworking Recommended Products
Olfa Knife
Comfortable plastic handle with a break off blade. A tool for breaking off the blade is built into the handy pocket clip.
Whiteside 9500 Solid Brass Router Inlay Router Bit Set
Set includes solid carbide down-cut spiral bit (for chip-free cutting), quick-change bushing, template guide and complete instructions. Fits Porter-Cable, Black & Decker and any router with a Porter-Cable bushing adapter.
Bosch ROS10 5-in. Random Orbit Sander
- Good stock removal and dust collection without a vacuum - Average for both with a vacuum - Handling was very good, but a little less so with a vacuum attached - Easy to grip around the waist
Veritas Micro-Adjust Wheel Marking Gauge
The adjuster runs through the beam from a small knob at the back end right to the cutting wheel, which moves in and out as you turn the knob. This arrangement works well but makes adjustments a two-handed operation, requiring a little more effort.
Drafting Tools
Add a hole guide to this kit, and you'll have the tools you need to work out your designs with scale drawings.
This post is archived.
