Looking to purchase 362 bdft of African Mahogany. The cost is $2.75 bdft, but the grade is No2 Common. I have only purchased S&B in the past, so I am a bit worried about the grade. Opinions?
Todd
Todd
If your projects are smaller and you can work around knots here and there . . . no worries. Kind of depends a little on what they're calling 2 common, but I'd expect it to be a little rough to deal with for anything that required some size to it.
Whats the cost relative to what you're paying for Select? Half? And is it worth the extra labor its going to take to process to get the lesser grade? Dunno. All stuff I'd think on.
Real trucks dont have sparkplugs
Todd ,
Sounds like you have used the African M before , so I guess you are familiar with it's characteristics . In a lower grade you most likely will have more of the undesirable wood to begin with , which imo will create more waste and not necessarily a better product .
To me African M is sketchy in the best grades so try and figure your normal waste factor times 2 to be safe and it may take more prep time to get it ready to use . Depending on the application and nature of the project you could come out ahead and with a better product with a higher grade .
regards dusty
From some recent projects i have worked on with African Mahogany the first question I have is which mahogany are you talking about?
The wood i got varied a lot in color and density. Sapelle is an African Mahogany as is Sipo....or so I am told; then there is this other wood.very light in color and weight that is called African mahogany. That being said I said I paid $6 /bf for sapelle and $5.75 for African. Both were FAS f4s. I still cant figure out just what African mahogany is. When you buy philipine mahogany you know whet youre getting..... I havent had such luck with African.
Wicked Decent Woodworks
(oldest woodworking shop in NH)
Rochester NH
" If the women dont find you handsome, they should at least find you handy........yessa!"
Todd,
With more knots present, there is likely also more figure. Go figure! (Pun intended)
