Does anyone have a sure-fire way to glue a 1″ wide edgeband to 3/4″ MDF? I remember reading something about thinning Titebond 1 to 1 with water to make a sealer, brush it on the MDF, let dry, then glue on the wood as usual.
kreuzie
kreuzie
I'd just Titebond the wood to the MDF directly. You might want to use a schosh more glue than usual; MDF will soak it up a little more than lumber does.
Attempting to seal the MDF with Titebond first strikes me as a bad idea. PVA does not bond very well to itself.
It's no big deal. I made a router table top 1.5 thick (2 3/4" pieces glued) Edge banded with oak. I used biscuits and used regular tight bond It's held for several years now with no sign of any issues. It is topped with formica
I agree! Mine is just WAX.
Just use the Titebond straight from the bottle.
David Ring
