Hi
I am building a railing for my sons verandah in Ottawa. I want to make the posts 4 inches by 4 inches. Will be gluing up 1 and 1/2 inch pine boards. What type of glue should I use to laminate the pieces together. Is the yellow wood glue good enough for outdoors Canada?
Roger
If you are talking about the waterproof version (Franklin's Woodworker II), it should do just fine.
Others will no doubt suggest either polyurethane (Gorilla), or an epoxy -- but I am in MN, and WWII has done the job.
Hi
Thanks for the quick response. Is that a yellow glue?
Roger
Yep. You should be able to find it wherever regular old Franklin glue is sold.
The Titebond rep tells me there new Titebond iii is better than the ii for outside work and yes it is yellow.
Can't you purchase 4x4 posts? If it's a veranda, I'm going to assume it's at least one floor up so falling is an issue. Not sure I'd trust the structure to glued up lumber.
Mark
Pine is one of the most decay prone woods there is. It is not a good choice for outdoor projects.
Waynel5 is right on the "money" regarding pine for outdoors - - go for western cedar - - it will still be there 20 years from now.
I agree with you Wayne. Cedar (red or Northern White) would be best. Fir is not a bad choice if it is painted- many exterior doors are made from it, but not if any part of the posts are below grade. As for gluing, I'd use Titebond III (yellow) glue.
Glaucon
Pine is one of the most decay prone woods there is..I'd bet Canada has more PINE that animals and people combined and can get good grade wood for a song..If you are building and prime/quality paint.. I think it would work..I made a deck for my brother in all pine.. I think that was about 25 years ago.. Still in OK shape... Chicago area here so winters not as bad as they are in Canada so maybe I'm all wet on this one.. I made sure all end grain was not exposed. Rails all had drip-groves (both sides of rail)and used screws so anything could be replaced.However, my brother did clean, scrape, repaint it about every four years.I used treated wood on another part of his house and it looks like C&ap!Pine worked better if maintained.. I forget what kind of pine I used...
I made some Adirondack chairs out of treated pine 15 years ago,they are as good today as when I made them,left them unstained etc,I like to see them weather into a nice grey.
I like to see them weather into a nice grey. My wife said that to me once!
Let me know where you're getting that wood for a song!
LePage Outdoor Wood Glue - white - is what I use on Muskoka chairs etc for the outdoors
for any gluing needs consult Lee Valley on Pinecrest Rd
whatever they sell you have 3 months to like it or take it back for a full refund
Titebond III also available at Busy Bee tools on Gladwin Cresc. behind McDonalds On StLaurent near Science & Tec Museum
