General International 6″/8″bench grinder
Hi,
I’ve been reading a lot lately about sharpening chisels and planes. Most people are against the sandpaper method of sharpening the primary bevel. They say it’s best to use a low rpm bench grinder to grind the Primary bevel.
Why choose an 8″ over a 6″ bench grinder? the wheels are both 3/4″ wide. Woudn’t the replacement wheels cost less if you went with a 6″ grinder. Any real advantage to purchasing the larger 8″ grinder.
Is HP important. The GI 6″ bench grinder is 1/3rd hp (18lbs) while their 8″ is 1/2hp 5amps. (30lbs) the 6″ costs approx. $109.00 and the 8″ sells for $169.00 Is it worth it to fork over the extra 60 bucks for the 8″ grinder or better to put that money to better use?
Any special features I should be looking for when choosing the right grinder?
Wanda
Well, the smaller the stone, the sharper the arc: the bigger the stone, the closer to flat the arc. And for most grinders you're gonna wanna buy a replacement stone that runs cooler.
Once I got my Veritas (spinning disc) Sharpener (has everything from coarse to very grits) I can regrind a fresh angle on a blade in a fraction of a minute, and I no longer needed a bench grinder.
