Hi –
I tried some Bartley Gel Varnish on some sample boards tonight and I started to wonder how much of it I should be trying to wipe off? Should I buff it off vigerously with a good bit of pressure or try to wipe it off more gently trying to leave a more visible thin film?
If I wipe to hard, do I run the risk of taking it all off? or if I go too light, risk leaving wipe marks?
Thanks in advance – John
JohnZ,
I'm not going to try and answer your question, I have a bit of experience, many here have much more to offer. However, before they can answer they will need more info. e.g. on bare wood or is this on top of something, what are your objectives for the gel(A&C look)and what kind of wood.
Here are a few more details: The wood is cherry. There is a washcoat of shellac on top of which I want to apply the gel varnish. The goal is a relatively thin coat which offers a medium level of protection.
Is it figured cherry ? ...just read the instruction on the can and follow it , work a section @ a time , used a spot light for clarity, must be the height of your work area , this will let u see your progress or lack thereoff.
cheers.
What does it say on the label instructions. I used it once years ago and just followed the label instructions. I didn't see any benefit to it and just stayed with using a thinned wipe-on varnish.
John,
I used a fair amount of the Bartley gel varnish when it was manufactured by Bartley (now made by Lawrence-McFadden). If it still is the same product, you really needed to remove almost all of the product, leaving the 'tightness' film possible.
Obviously with this product you are not going to build much of a film thickness, from what I remember 3 to 4 applications gives a nice soft glow..Just a caution, you are not going to get tons of protection from this product..
Edited 10/20/2009 3:32 pm ET by BOBABEUI
Thanks Bob - That was what I was wondering about. - John
