I’m working on an experiment. In my latest project, a cherry hutch, I’m using cherry. While discussing the project, someone suggested fuming the cherry with amonia to in the words of my friend add 15 years of patina. Well I conducted a test yesterday. I took two pieces of cherry and sanded each equally, and put one in a bag and raised the piece off the bottom and put a bowl of 10% amonia and left it for 24 hours and left the control piece out. Well I removed tonight and the fumed piece was very dark, but to the point of appearing greenish in color. I wiped down with mineral spirits and it still had a dark look but not very cherry looking. Anyway I’m wondering if the color will modify after exposure to air, or is greenish looking normal. If so, I’m not a fan of fuming cherry. Anybody here fumed cherry?
bones
The typical fumigation of wood with ammonia is done with a commercial grade of ammonia. If you used regular household ammonia, you will not receive the same satisfactory results.
On a side note, there is no reason, in my silly little worthless opinion, to mess with chemicals on such a beautiful wood as cherry. If you need patina, give it a suntan. Otherwise, you can use an amber shellac to achieve the 'orange-brown' of cherry without messing with an abusive and toxic grade of ammonia. Or, even a dye stain from Transtint.
This advice is free, and should be considered as valuable as its cost.
Give it a day or two to "air out," then assess the color. Fumed oak also looks unpleasantly pea-greenish when you first take it out of the fuming chamber.
Thanks. I planned on doing that hoping it would calm down. The aroma is still heavy on the wood. I'd hope that will fade as well. The ACE ammonia even at 10% was powerful and even with the mask on, burnt the eyes a tad. Nasty stuff. I'm going to finish both the test board and the control board and compare. I'll post a pic after I'm done.
Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Edited 3/4/2008 9:59 am by bones
I agree with Jeff in that it's not really needed. I tried it a while back turned out alright. I used commercial grade ammonia I got from a printing shop, and I fumed the cherry for about 4 hours if memory serves. Read this article by Kevin Rodel, he shows the results of fuming a few different types of wood. Cheers.
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2485Russ.
http://www.jensenfinefurniture.com
Add me to the list of "Why?!" speakers. Sunlight, even artificial, will do wonders.
