I need to use 1/4″ dovel at the joint between a curved leg and seat base (both cherry). This piece does not fit under my table top drill press so I decided to drill free hand. Test efforts turned out horrible. Any suggestion will be much help. Which bit? How to steady the drill? etc.
Thanks in advance.
I like the inexpensive spade bits for a couple of reasons. The long pointed tip is an aid when trying to hold the drill on target and align it with where you want to go. They are easy to sharpen with a file, and they can be sized for a perfect fit by filing a little off the sides. When you have to align two parts, you can drill one side and insert a dowel center, then push the pieces together so that the center marks the location for the other piece. You can make a story block, hold a square or set a sliding T-bevel for the angle to help eyeball your drill. It's best to go slow and keep checking. In some situations, you can use a dowel drilling jig or make one by drilling a hole through a block and clamping it to your work. Another approach, if you have a bench mounted drill press, is to swing the head so that you have no restrictions other than the floor. You could clamp the piece to the side or end of the bench.
Thanks, for two very useful answers.
I own spade bits and it should be easy enough to make a guide out of thick stock.
I will try it this weekend.
KS,
If possible in your situation, drill a guide, or pilot, hole the size of the dowel thru a fairly thick block. Clamp the block in place onto one of the pieces that you are joining. Drill thru the hole into your stock. Use a dowel center to locate the position of the mating hole. Use the point of your bit through the block, to find the location of the second hole, then clamp the block, and drill.
