Follow-up to “How strong is your glue” july/august 2007
This was a great article. It looked at joint fit (tight, snug and loose), wood type (tight grain, open grain and tropical hardwood) as well as the most common glue types. It provided the breaking point for each of the fit-classes, wood types and glues used on 162 or so test pieces. The one thing it did not provide was the dimensions of the test pieces. As a retired techno-weenie, I would like that so that I could convert the failure loads to failure stresses. That would make the information more universal, allowing you to use it with some confidence on larger or smaller projects.
I understand that the values are averages and that every piece of wood we handle is at least a little different from other boards cut from the same tree. That said, using a conservative safety factor should go a long way to addressing the variability.
Can anyone help with those dimensions?
Thank you. Any help is a big help and it is appreciated.
Joe
Glue test joint size
Hi Joe,
There should be a statute of limitations on questions about old articles! According to the post-issue reader survey this was the most popular article ever in FWW and I had kept a couple of spare joints as souvenirs. Unfortunately when we moved house three years ago they went in the wood stove along with alot of other workshop clutter. Measuring the photo on the cover, drawing the joint full size, I am pretty sure that the joints were 3/4 in. thick, 1 1/2 in. wide and 3 1/2 in. long but I can't be 100% certain.
Sorry I can't be positive but I hope this helps.
Mark Schofield.
